Nov 30, 2013 - 8:31 PM
Enthusiast ![]() Joined Dec 20, '11 From gta Currently Offline Reputation: 0 (0%) |
New battery got it started. Barely. There is a high pitched squealing sound when the engine turns on. Is it a pulley? At first I thought it was the oil, so I topped it up. The starter is fine too. I cannot get it to run though. Is this an easy diagnosis? The burning smells like rubber. How much to fix at a shop? Or can I do it myself? Thanks.
This post has been edited by gts4: Dec 1, 2013 - 5:34 AM |
Dec 1, 2013 - 11:00 AM
Enthusiast ![]() ![]() ![]() Joined Aug 31, '02 From KC Currently Offline Reputation: 0 (0%) |
New battery got it started. Barely. There is a high pitched squealing sound when the engine turns on. Is it a pulley? At first I thought it was the oil, so I topped it up. The starter is fine too. I cannot get it to run though. Is this an easy diagnosis? The burning smells like rubber. How much to fix at a shop? Or can I do it myself? Thanks. sounds like the alternator or power steering pump or air cond etc may have a frozen bearing or possibly just have a loose belt, check for loose belts, if all tight, start it up and look to see if something is not turning under the hood? |
Dec 1, 2013 - 12:03 PM
^^^ what he said
| Lo-Fi Version | Time is now: August 23rd, 2026 - 5:19 AM |
