> Lifted st
post Dec 10, 2013 - 10:20 PM
bnwzalek
Joined Feb 20, '13
From baltimore
So I recently totaled my beams swapped celery... Now I have an st, and I want to lift it... Which struts / springs could fit on it to give it a bigger lift? Anything off the old toyota trucks?
post Dec 12, 2013 - 10:50 PM
emm, ah, ohhh, what?
why do you want to lift? do you have lowering springs, and want to go to oem?
but maybe air suspension comes to mind..... but almost no one goes the way of the lift..
post Dec 13, 2013 - 12:20 AM
PegGTS
Joined Apr 15, '13
From Winnipeg, MB, Canada
QUOTE (njccmd2002 @ Dec 12, 2013 - 9:50 PM) *
I've always been curious how that would look haha
Please do it to satisfy my curiosity
2007 Impreza 2.5i - Daily
1994 Camry - Sold
1994 Celica - Sold :(
Click here to see my progress thread!
post Dec 14, 2013 - 1:36 AM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Would you be able to use struts an spring off a Camry or something
That might be alil taller
94 st hatch my daily driver
n
post Dec 14, 2013 - 8:34 AM
Ted95
Joined Mar 8, '09
From Westport, MA
Maybes 4runner? The front calipe setup is supposed to fit the front GT knuckle so that might be a lead. I know you mentioned havig an st so you might have to swap different parts around to make it work, I don't think you'll just simply swap struts and be done with it. Be interesting to see done tho, also look into the mini tacomas possibly.
st205 powered ss3 coupe
post Dec 14, 2013 - 8:55 AM
top mount spacers.
post Dec 14, 2013 - 9:22 AM
Ted95
Joined Mar 8, '09
From Westport, MA
^^ that's brilliant.
post Dec 14, 2013 - 12:03 PM
H8TRAIN
Joined Oct 20, '13
From Cal Bay Area
The spacers are good. And they reduce uptravel, making room for taller tires, further raising the ride height.
Combining the suspension lift with taller tires would get you to your desired ride height without making the arms have to "reach down" as far.
What is your desired ride height? Maybe you can measure how many inches high your crossmember is now and we can compare it to where you want it to be and come up with something.
Lo-Fi Version Time is now: August 22nd, 2026 - 10:32 AM
