> gas pedal sticking
post Dec 20, 2013 - 10:31 PM
Terzin1
Joined Feb 19, '05
From Indianapolis
I've noticed my celi's gas pedal has been sticking coming from complete stops. Is there a common place to look to lube something up? I'm hoping its as simple as that and not something to do with the tranny.
For the best designs and screen printing.
WE DON'T PRINT UGLY.
www.TERZink.com
post Dec 21, 2013 - 8:25 AM
garin
Joined Aug 12, '07
From Lancaster, Pa
try adjusting the throttle cable at the throttle body. thats the best place to start. maybe clean the throttle body too.
post Dec 22, 2013 - 1:27 AM
RabidTRD
Joined May 31, '11
From Rochester, NY
Clean the throttlebody. Carbon buildup usually does this. Also try some white lithium on the cable and work it into the cable conduit.
post Dec 22, 2013 - 1:46 AM
JasonTX
Joined Mar 1, '10
From TX
QUOTE (RabidTRD @ Dec 22, 2013 - 2:27 AM) *
^this
i had very similar symptoms as yours. i have a point in the bend of my cable where it cracked and exposed the metal coil inside. because i dont drive my celi often sometimes a little rust or something develops i spray some wd40 in there and work the cable untill its smooth again. i find i have to do it every few months if i let the car sit.
JN 3:16
Lo-Fi Version Time is now: August 25th, 2026 - 3:29 PM
