Jan 4, 2014 - 1:06 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Aug 11, '08 From London Currently Offline Reputation: 7 (100%) |
Im trying tk wire a booster antenna and it requires a 12v supply.
The stock antenna has a plug to the motor with 5 wires. Which one of them is the 12v which powers the motor? |
Jan 4, 2014 - 1:10 PM
If you turn the plug to face you, it has a U shape. If I remember right, it's the two wires on the left side, one is constant and one is switched. I can't remember the wire colors at the moment but I'll walk outside and check in a little bit.
Jan 4, 2014 - 3:12 PM
Jan 4, 2014 - 3:42 PM
Our wire colors are different but the plug looks the same. Holding my plug the same way yours is, it would be my top right wire that is switched power. On my plug, it's sort of a tan/gray wire but on yours, the wire looks like a regular gray. The wire color may be different between our plugs but I can't imagine Toyota used a completely different antenna or wiring schematics between an ST204 and ST205.
Jan 7, 2014 - 3:52 AM
Thanks Rich. Thats the one.
Jan 7, 2014 - 3:56 AM
Any time.
| Lo-Fi Version | Time is now: August 9th, 2026 - 10:04 AM |
