Jan 8, 2014 - 10:35 PM
Enthusiast ![]() ![]() ![]() Joined May 23, '12 From northridge,CA Currently Offline Reputation: 3 (100%) |
ok having big issues with 3d gen 3sge
st204 swap. so turn on engine poor idle, idle jumps around 750-900 car wont rev smooth at sll anytime u rev it goes up then down to like 200 rpms ad back up to 750, seems like its running rich, new oem spark plugs and already black, was using oem parts that came with the engine so then trouble shooting i switched igniter off 5sfe switched tps sensor off my 5sfe the map sensor the distributor rotor, and same issue i need help!!! |
mi645 3d gen 3sge problems Jan 8, 2014 - 10:35 PM
Rusty Any CEL codes? I'm sure something would be pop... Jan 9, 2014 - 6:18 PM
mi645 quarter tank 91 gas.
lof lube and oil filter.
cam ... Jan 9, 2014 - 9:49 PM
Rusty Ok, and the CEL codes and the fuel age? Jan 10, 2014 - 3:18 PM
mi645 no cel codes atm even when i plug te1 and e1
fuel ... Jan 10, 2014 - 4:44 PM
Rusty Yeah a few ideas, just trying to get more of an id... Jan 10, 2014 - 9:58 PM
mi645 tps chaned and adjusted isc cleaned and adjusted.
... Jan 10, 2014 - 11:22 PM
Rusty Interesting. As those parts are the most likely th... Jan 11, 2014 - 3:46 PM
mi645 all eiring was connevted correctly i just took it ... Jan 11, 2014 - 8:07 PM![]() ![]() |
| Lo-Fi Version | Time is now: September 14th, 2026 - 2:21 AM |
