> How much ignition coil do you really need?, at least w/o forced induction
post Jan 11, 2014 - 12:16 AM
VavAlephVav
Joined Dec 3, '13
From Missourah
as I peruse the ignition coil section of the parts catalog I begin to wonder, Just how much coil do you need for a stock setup?
I imagine that the really cheap are probably really cheaply made, and I could believe the ones that are about $60 are a higher quality.
But the top of the line ones are like $100 more. yikes.
So how much coil do you really need, or can you actually put to use on a stock motor? (5s-fe) and I have federal emission setup with coil in the dist cap.
I imagine that maybe the turbo charged ones could use more
so if you check www.rockauto.com , at least under the 94 2.2 you can choose from
Ultrapower for $20
http://www.rockauto.com/catalog/moreinfo.p...&cc=1274307
Standard Motor for $37
Delphi for $55
AC Delco for $63
And then the Bosh coil is $130 WTF?
So how much coil can you actually get performance from with a stock 2.2L?
Bust a Deal; Face the Wheel.
Lo-Fi Version Time is now: September 14th, 2026 - 4:31 AM
