Jan 14, 2014 - 3:28 PM
Enthusiast ![]() ![]() Joined Sep 6, '12 From Holland Currently Offline Reputation: 1 (100%) |
Hello,
Can someone tell me the exact Celica SS3 Beams exhaust diameters? I'm curious what the diameter is of the middle centre and of the pipe that goes to the muffler. Please mention if you're measuring inside or outside diameters. As for as i know the beams uses the same piping as the europe 3SGE Gen 3 engines and that's an outside diameter of 2". Thanks -------------------- |
Jan 14, 2014 - 3:41 PM
Outside is 2.25".
Jan 14, 2014 - 3:44 PM
![]() Enthusiast ![]() Joined Jan 8, '13 From New Zealand Currently Offline Reputation: 0 (0%) |
I have a feeling it is 2.25" unless my muffler section has been changed, pretty sure it's factory.
EDIT: well there you go ^ This post has been edited by Mo_tron: Jan 14, 2014 - 3:45 PM -------------------- QUOTE (madbeardo @ Mar 27, 2013 - 8:17 PM)
When said about modification I didn't mean the ones made by man. What I said was that it might have modified after being affected by a certain force. |
Jan 14, 2014 - 3:50 PM
Okay thanks a lot. I might grab a beams exhaust then (if available) for my 4AGE 20V Blacktop. I wanted to go for 2" OD but that might be a bit too small for the blacktop regarding the fact it hits 8200 rpm sometimes. I think 2.5"might be a bit too thick. 2.25" seems to be perfect but over here most people that make customs exhausts do have 2" or 2.5" mufflers but not 2.25"
| Lo-Fi Version | Time is now: May 29th, 2026 - 12:32 PM |
