Jan 25, 2014 - 7:41 PM
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) |
The C52 Transmission:
General info: Type of Transaxle: C52-0#A Manual Notes: Open differential (A) Type of Engine: 7A-FE Model: AT200 Transaxle type C52 uses constant mesh synchronizers for forward gears and a sliding mesh reverse gear. The input shaft is composed of the 1st and 2nd speed gears and the reverse drive gear, and the output shaft is composed of the drive gear (for use with ring gear). Gear Ratio: 1st Gear: 3.166 2nd Gear: 1.904 3rd Gear: 1.310 4th Gear: 0.969 5th Gear: 0.815 Reverse Gear: -3.250 Differential Gear ratio: 4.058 Maintenance Oil Capacity: 2.6L (2.7 US qts, 2.3 Imp. qts) Oil Viscosity: SAE 75W - 90 Oil Grade: API GL-4 or GL-5 Troubleshooting Use the table below to help you find the cause of the problem. The numbers indicate the priority of the likely cause of problem. Check each part in order. If necessary, replace these parts. ![]() Pictures: ![]() The engagement of the transaxle gears.
| Lo-Fi Version | Time is now: July 28th, 2026 - 11:44 AM |
