> Forged st205 GT3082r on STOCK ecu possible???, Help!!!
post Jan 30, 2014 - 10:17 AM
Dudleydaftdog
Joined Dec 31, '13
From Yorkshire England
Hi All,
Just wondered if Amy of you guys could please shed some light on my problem...
I have a forged st205 and was running a hks f con v pro with sard 800s and a gt3082r turbo. My F con has died!!! Had to refit the stock 550 injectors (running at 4 bar (closer to 650s) on the STOCK. ecu. Ext WG spring is only set @ 8 psi.
Question:
Has anyone ever tried this before? (Read TRDGT4 tried it but doesn't say what GT30 turbo in the old thread)
Basic engine wpec
St185 bottom end, 8.2CR, Forged pistons and rods, ACL race series everything, ARP everything, hks 256 cams, cosmetic 1.5mm hg, Kevlar cambelt, meth ink, JUN valvetrain, FMIC, 3 inch decay as exh etc etc..
If anyone could please advise me is be really grateful. Seems to drive fine off boost (wideband between 14-15), tips in a bit lean, just scared to boost!!!!!
Thanks in advance
Chris
Lo-Fi Version Time is now: July 29th, 2026 - 2:52 AM
