Jan 31, 2014 - 3:56 PM
Enthusiast Joined Jan 31, '14 From Anglesey N. Wales Currently Offline Reputation: 0 (0%) |
Hi there im hoping you can help me with a problem.
I have a 94' gt import and the other day when I started the car it was fine, but when it came down to idle revs around 700-800 rpm it just started hunting, now also when i am actually driving and i apply the brakes the car cuts out completely. Any ideas PLEASE HELP Jonathan |
Jan 31, 2014 - 5:49 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Dec 3, '13 From Missourah Currently Offline Reputation: 0 (0%) |
first I would check things like the Idle Air-speed Control IAC. it has a little piston that gets caked with carbon gunk, some say you might be able to clean it, but if it's bad enough to make the car die you'll need to
get a new one. and I think this is one of those parts you would be glad to get one from Toyota 'cause the aftermarket sensors/electronics don't always work right. otherwise check regular stuff like the fuel filter, plugs/wires, bad gas, ect. -------------------- Bust a Deal; Face the Wheel.
| Lo-Fi Version | Time is now: May 26th, 2026 - 11:51 AM |
