Feb 1, 2014 - 3:08 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Dec 3, '13 From Missourah Currently Offline Reputation: 0 (0%) |
So I've been reading the available threads on this subject and have just a few more questions...
given there are no 94-99 turbos likely to be lying around in the US, would you just find one from the turbo 91-93 motor? (or is there a particular year that works best) I have seen that you need a special head gasket (can't find that thread rtm) to make it work right, especially since I have one of the later model 5sfe. but it just bolts right on right? other than that what else will have to be changed? I'm guessing you will have to use the distributor system from the 3sgte, but will the cam sensor plug right in or do you have to change the ECU or other electronics as well? and the timing belt side? surely the 5sfe timing belt won't fit, do you just use the 3sgte belt with the 5s tensioner/idler ect? or are there other modifications needed? So I understand that the 5s doesn't have race quality components in the bottom, and I wouldn't expect it to just bolt up and be that amazing, yet I bet it'd be a big improvement just to swap the head and still run it N/A. I imagine you need the exhaust header for the 3sgte as well, what about the intake manifold? It's just that I have to replace the head gasket anyway, and if once he opens it up and would find that there's actually a crack in the head itself then I may consider getting this head instead of getting the regular 5s head. some of the threads I've been getting this from http://www.roadandtrack.net.au/images/stor..._5SG_engine.pdf http://www.6gc.net/forums/index.php?showtopic=5574 can anybody help me find the thread that had a link to the site that sells the special head gasket again? I cant find it :{ -------------------- Bust a Deal; Face the Wheel.
VavAlephVav 5sfe + 3sgte head Feb 1, 2014 - 3:08 PM
ILoveMySilly97 A homemade cardboard headgasket. Lol! J/p. I... Feb 1, 2014 - 3:19 PM
VavAlephVav ha, I just saw a thread yesterday that talked abo... Feb 1, 2014 - 3:56 PM
presure2 swapping a 3s head on a 5s is basicly a 3sgte swap... Feb 1, 2014 - 6:11 PM
RabidTRD Therefore it's more worthwhile from a time and... Feb 1, 2014 - 8:57 PM
VavAlephVav which is pretty much what I had gathered from the ... Feb 1, 2014 - 10:29 PM
TRDweaponX I called Gude awhile back about their head package... Feb 1, 2014 - 11:33 PM
Smaay you also need to use the 3S-GTE coil, igniter, and... Feb 1, 2014 - 11:41 PM![]() ![]() |
| Lo-Fi Version | Time is now: July 30th, 2026 - 7:28 PM |
