> Rotor Arm 7AFE
post Feb 9, 2014 - 5:39 PM
englishdas
Joined Jan 22, '14
From South Yorkshire, UK
just took my Distro cover off, as my ST has a bit of a judder when accelerating at lower revs and I;ve started to investigate...
Here's the rotor arm:
looks like a fair bit of corrosion. questions:
1. could this be the issue?
2. it needs replacing, right?
post Feb 9, 2014 - 7:36 PM
VavAlephVav
Joined Dec 3, '13
From Missourah
yep, electicity don't want to flow so easy through crusty stuff
probably need the cap as well , check the inside pins where the rotor makes contact with them
http://www.6gc.net/forums/index.php?showtopic=91916
probably needs wires/plugs as well,
Bust a Deal; Face the Wheel.
post Feb 10, 2014 - 4:39 AM
englishdas
Joined Jan 22, '14
QUOTE (VavAlephVav @ Feb 9, 2014 - 7:36 PM) *
Appreciate it, my friend, I've ordered a new rotor arm. Will check the pins, but yeah, they're gonna be rough, aren't they. Plugs are fine and Ive looked into ordering Stock leads, no point going for NGK heavy duty, it's not a performance car, is it.
Should have her running smooth by the weekend.
will post pics of Distro cap pins and replace if necessary. Thanks for the link to the thread, I know what to look for now.
much nicer to work on a car that has a simple ignition system, I actually understand the process of ignition and combustion on a car like this!
post Feb 10, 2014 - 10:24 AM
VavAlephVav
Joined Dec 3, '13
From Missourah
Ya, mine runs SO much better with new plugs/wire/cap/rotor. You really notice the difference once you spin it up to 4-5k
And the people who told me to be sure and use ngk or Denso plugs were so right, even with copper plugs ngk is superior quality and what is recommended by Toyota.
I ordered it all on rockauto.com and got a super deal on everything
This post has been edited by VavAlephVav: Feb 10, 2014 - 10:27 AM
post Feb 10, 2014 - 2:57 PM
englishdas
Joined Jan 22, '14
QUOTE (VavAlephVav @ Feb 10, 2014 - 10:24 AM) *
I've got some leads bookmarked, these: Bosch lifetime wires
and these: NGK 8128
But, tell you what, I'm glad you mentioned checking the points in the Distro Cap:
How rough do those posts look???!
So one of them is going on order as well...
Looking forward to smooth ignition, Plugs ordered too, NGK Iridium.
post Feb 11, 2014 - 10:44 PM
VavAlephVav
Joined Dec 3, '13
From Missourah
mine seems to be suddenly using a bit more fuel than it did before, I'm guessing that it's a good idea to pull the ecu and efi fuses to reset the computer after
the new ignition parts are installed.
post Feb 12, 2014 - 8:35 AM
englishdas
Joined Jan 22, '14
I read about that in a sticky, I think. Let me know if it works. My parts should be here tomorrow smile.gif
post Feb 13, 2014 - 7:26 AM
englishdas
Joined Jan 22, '14
The Rotor Arm arrived today, it looks different...
Is it gonna work, or is it gonna rip my Distro points to shreds? How can I check without turning the engine over?
post Feb 13, 2014 - 8:22 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
Just put it back to back with the one on there now and make sure it's the same length, it should be ok as long as it is.
post Mar 10, 2014 - 9:33 AM
englishdas
Joined Jan 22, '14
New Distro fitted today, matched Rotor arm up to existing rotor as suggested by Bitter, and
Boom! no judder at junctions, power delivery smooth as hell, feels like a big change in response. I know 75% of perceived improvement is psychological, but good grief, it's definitely made a difference.
Just waiting for NGKs and Plug leads to finally get here, then Cold Air intake next...
Lo-Fi Version Time is now: September 12th, 2026 - 8:02 PM
