Closed TopicStart new topic
> FS: Four 20mm Ichiba Spacers SOLD! MODS CLOSE!, SOLD! MODS CLOSE!
post Feb 14, 2014 - 4:10 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
FS: 4 X 20mm Ichiba Spacer : $135 shipped : 5x100 : 54.1 centerbore : Includes 20 extended studs : Located in Hanford, Ca : Text me at 1-559-380-5764.
Im willing to part out for $75 shipped for a pair if split the set with another buyer.
Note the two painted red are kind of stripped but they can still be used. I've tested them all and those two are the only ones that needs a bit more tug. It didn't strip my nut and it reversed out fine.
Here's how I installed my extended studs. Not hard to do.
http://www.youtube.com/watch?v=B0VIEGcJJ-U
This post has been edited by ILoveMySilly97: Apr 4, 2014 - 4:55 AM
post Feb 22, 2014 - 5:27 PM
ILoveMySilly97
Joined Mar 8, '12
Updated post.
post Feb 26, 2014 - 6:50 AM
ILoveMySilly97
Joined Mar 8, '12
bump!
post Feb 26, 2014 - 1:46 PM
SupraKid
Joined Aug 15, '10
From The Best Coast
My offer still stands.
post Feb 26, 2014 - 2:02 PM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (SupraKid @ Feb 26, 2014 - 10:46 AM) *
was it you who was texting me the other days?
post Feb 26, 2014 - 4:08 PM
SupraKid
Joined Aug 15, '10
From The Best Coast
QUOTE (ILoveMySilly97 @ Feb 26, 2014 - 11:02 AM) *
No, I sent you a message on here.
post Feb 26, 2014 - 7:23 PM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (SupraKid @ Feb 26, 2014 - 1:08 PM) *
Oh yea. Sorry. Deleted the message. You wanted only a pair right? If no one buys it as a set anytime soon then I'll end up selling you a pair.
post Feb 26, 2014 - 8:40 PM
mkernz22
Joined May 10, '10
From MA
QUOTE (ILoveMySilly97 @ Feb 26, 2014 - 7:23 PM) *
I offered to buy a pair too. Would have worked perfect.
post Mar 3, 2014 - 1:02 AM
cwong
Joined Jun 8, '13
From goldsboro, NC
http://www.amazon.com/gp/aw/d/B004AGH6KW?c...354&sr=8-16
Correct me if im wrong but isn't this the same thing.
If it is isnt yours kinda pricey
post Mar 3, 2014 - 1:17 AM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (cwong @ Mar 2, 2014 - 10:02 PM) *
It's similar but different. Your post has only a pair so only two spacers. Two for the front or two for the rear. Also it's bolt on so the stock studs is going to be hitting into your rim unless your rim has extra space to clear the stock studs. Mine has a full set which has four spacers for all four corners. Mine is extended studs so you'll need to press in the new extended studs and don't got to worry about the stud clearance issue. Price wise. I'd say mine is reasonable. If you buy a full brand new set it's double what you posted which is around $240-$260 total.
This post has been edited by ILoveMySilly97: Mar 3, 2014 - 1:40 AM
post Mar 3, 2014 - 8:25 AM
mkernz22
Joined May 10, '10
From MA
QUOTE (ILoveMySilly97 @ Mar 3, 2014 - 1:17 AM) *
Just to correct you on one thing, stock studs will be fine with 20mm bolt on spacers. The spacers are thick enough so that the stock studs don't stick out and hit the wheel. If you have extended studs, that's when you'll have a problem with the studs hitting the wheels (unless there's a space in the wheel so that they don't).
post Mar 3, 2014 - 11:12 AM
ILoveMySilly97
Joined Mar 8, '12
^no mkernz. What I said was correct. You got it the other way around. Extended studs replaces the stock studs so the stock studs wont even be on your car anymore. There for how is it you only have the 5 extended studs on each corner that well go through the 5 holes in each rim. The bolt on will double your studs on each corner. That's when you have the rim space/clearance issue.
post Mar 3, 2014 - 11:57 AM
richee3
Joined Jun 29, '08
From Denver
Currently Online
You guys are saying the same thing. Mike said that stock studs with 20 mm bolt on spacers will be fine, but extended studs with bolt on spacers will be a problem. Mike was referring to bolt on spacers only. Simple miscommunication. smile.gif
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Mar 3, 2014 - 12:55 PM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (richee3 @ Mar 3, 2014 - 8:57 AM) *
Oh. I see what you mean now. Im not too sure if the 20mm bolt on is thick enough to clear the stock stud. I never confirmed it before. All I know is that our stock studs is less than 25mm long so 25mm+ bolt on is a for sure no stock stud issue.
post Mar 3, 2014 - 1:44 PM
mkernz22
Joined May 10, '10
From MA
QUOTE (ILoveMySilly97 @ Mar 3, 2014 - 12:55 PM) *
I'm confirming it because I had 20mm bolt-on's at one point...
post Mar 11, 2014 - 11:42 AM
ILoveMySilly97
Joined Mar 8, '12
bump! Mkernz needs a pair buddy. Lol.
post Mar 11, 2014 - 1:04 PM
richee3
Joined Jun 29, '08
From Denver
Currently Online
I can take them if nobody else is in line.
1998 Celica GT-
BEAMS Swapped.
post Mar 11, 2014 - 1:08 PM
mkernz22
Joined May 10, '10
From MA
Well I want them, but I only need two cause I'm moving my 15mm's to the front (replacing the 10mm's already there), and putting the 20mm's in the rear.
post Mar 11, 2014 - 1:20 PM
richee3
Joined Jun 29, '08
From Denver
Currently Online
I guess I didn't specify. tongue.gif I can take the other pair if Andrew isn't interested in them anymore.
1998 Celica GT-
BEAMS Swapped.
post Mar 11, 2014 - 1:24 PM
mkernz22
Joined May 10, '10
From MA
oh alright, swwweeeeet!
I'll take the two bad studs if you need all the good ones?
I already have extended studs so it's not a huge deal to me
Lo-Fi Version Time is now: July 29th, 2026 - 9:21 PM
