Feb 19, 2014 - 8:41 PM
Enthusiast ![]() Joined Sep 16, '13 From Grand Rapids, MI USA Currently Offline Reputation: 1 (100%) |
On the surface, LED taillight bulbs from eBay look good (as good as cheap ebay stuff can be that is). However in the fine print, they say that load resistors may be needed. What has your experience been?
I am looking at possibly adding some tint to my taillights and use super-bright red, amber and white LED lamps to make up the difference. -------------------- '99 Triple Black GT Convertible
Check out the "Michigan Toyota Scion and Lexus Crew" on Facebook. |
Feb 19, 2014 - 8:53 PM
Enthusiast ![]() Joined Jan 27, '14 From Fort Wayne IN Currently Offline Reputation: 0 (50%) |
You need them so your car doesn't have hyperflash. Hyperflash is like when you have a bulb out, your car tells you by flashing that side quicker than usual. It's the way the flasher relay is designed that that happens. Newer cars do not need them depending on the model, since they have body control modules. You need either load resistors, or a led flasher relay. I'd also recommend superbrightleds.com you can enter your model and get exactly what you need. They also show both the resistors and relays you can purchase. Mine came hella quick. They also have good customer service.
Relays I figure are easier since the one is only 10$ instead of 2-3 each light, and no tools required to wire them in. That's why I went with it. -------------------- 94 Teal GT-DD 223,915 miles SOLD
99 WHT GT- Race car! Or just AutoX Car getting rebuilt then susp and turbo! |
Feb 19, 2014 - 9:29 PM
Enthusiast ![]() ![]() ![]() Joined Oct 3, '10 From Lansing, MI Currently Offline Reputation: 2 (100%) |
You need them so your car doesn't have hyperflash. Hyperflash is like when you have a bulb out, your car tells you by flashing that side quicker than usual. It's the way the flasher relay is designed that that happens. Newer cars do not need them depending on the model, since they have body control modules. You need either load resistors, or a led flasher relay. I'd also recommend superbrightleds.com you can enter your model and get exactly what you need. They also show both the resistors and relays you can purchase. Mine came hella quick. They also have good customer service. Relays I figure are easier since the one is only 10$ instead of 2-3 each light, and no tools required to wire them in. That's why I went with it. I'd like to see the result and maybe inserted in this conversion. Take pics... |
Feb 19, 2014 - 10:00 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 22, '06 From Columbia, MD Currently Offline Reputation: 13 (100%) |
right are LED's
-------------------- ![]() 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Feb 19, 2014 - 10:06 PM
Pictures do not do it justice. I never thought I'd drop the 20$ on bulbs just for my cluster when I saw the pics. Got my tax return back and splurged a little. Now I'm kicking myself for not doing it sooner. It looks cool, its brighter, they last longer, and they modernize your car.
IMO they are worth the money. -------------------- 94 Teal GT-DD 223,915 miles SOLD
Feb 19, 2014 - 10:12 PM
Feb 19, 2014 - 10:19 PM
Enthusiast ![]() ![]() Joined Dec 9, '13 From Melbourne, Australia Currently Offline Reputation: 2 (100%) |
I'm more interested in having something like this
This post has been edited by RoadRage: Feb 19, 2014 - 10:28 PM -------------------- |
Feb 20, 2014 - 7:36 AM
You can do just about anything you want. But to answer your question, you will still need some type of load to prevent hyperflash. Not sure if some LED's come with them built in.
Feb 20, 2014 - 8:04 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Apr 12, '13 Currently Offline Reputation: 53 (100%) |
Split the wire, connect the old bulb, hide it, no need to spend extra money on loaders and relays. Ghetto, but works.
Feb 20, 2014 - 7:12 PM
I checked superbrightleds.com and it looks like I need can-bus bulbs. Designed to not need loaders or relays. $20/bulb on the site. Two for $16.00 on ebay.
Feb 20, 2014 - 7:37 PM
No, not the CAN bulbs. Go one under that. I didn't use those in mine and they were like 5$ something per bulb. And you Dont have to wait 7 weeks for them to get to your door from China.
Feb 21, 2014 - 4:00 AM
Enthusiast ![]() ![]() Joined Nov 21, '05 From England Currently Offline Reputation: 6 (100%) |
I believe you only need to use the expensive CAN type bulbs if they're being used in a circuit which has a 'bulb fail' warning lamp or something similar.
Good example of this is the 3rd brake light. On some model/year/markets(GT4's in particular) which have this function, if you fit a regular LED bulb/strip, the brake light fail lamp on the dash will light. Another ghetto solution to this is to just remove the bulb from the dash! -------------------- Has your car ever been on T.V? Mine was used in the opening sequences here - note the clear turns and front LED's
http://videos.streetfire.net/video/Wheeler...11-9c0f00a0b820 |
Feb 21, 2014 - 11:38 AM
Ah. I guess that was in my friends Camry. My celica didn't have it and I had no problem with mine. You can pop the bulb out from the dash when doing led cluster mod
| Lo-Fi Version | Time is now: March 22nd, 2026 - 2:37 AM |
