> Fans shut off again!
post Mar 2, 2014 - 3:38 AM
match220
Joined May 13, '06
From Kaimuki, HI
Ignore me if you want...I'm just venting. This is getting very very irritating, not to mention having to ride my motorcycle in the pouring rain to work because my fans crapped out again. I troubleshot the whole system last week, found the problem being the connection at the 100amp fuse, once I shifted the fuse the fans came on. Replaced the fuse and it worked great. Now they are off again. Everything I wired in on my aftermarket ecu works great, it's the stock wiring that wasn't touched that is giving me problems. I'm really close to ripping out the entire wiring system for the fans and doing it my way so I have a backup way to flip a switch and power the fans if all else fails. It is highly irritating losing fans, especially when it is pouring rain and I have to get soaked on the way to work.
First I'll probably just clean the ground connections and the fuse connections, then get some relays and wire them in as a secondary fan switch with their own power, fuses, and kill switch. I love the way Toyota designed it, how it's made to be always on if a ground connection is lost, but seriously it's about to go whether that is a full redesign or modification.
-Jay
95 GT conv. project car: Manual, Gen III 3sgte, JN pisons, Eagle rods, overbore, crank knife-edged, crank scraper, ARP head/main/flywheel, Autronic EMS, Haltech Dual Wideband O2 controller, Audi 1.8T individual coils, FMIC and SSQV BOV, 3" downpipe, 3" ultra-high-flow cat, 2.5" Borla muffler, +other
01 S2000: FMIC, Haltech EMS, Haltech wideband, 570cc inj, forged pistons/rods, sleeved block, 5 angle valve job, ported and polished
02 R6, all stock, except for braided stainless brake lines, frame sliders, and adjustable brake/clutch leve
post Mar 10, 2014 - 9:37 AM
englishdas
Joined Jan 22, '14
From South Yorkshire, UK
Between us we could have a good car.
Mine has the fan running constantly.
Don't know what the deal is, may start a thread.
Hope you get yrs sorted fella.
Lo-Fi Version Time is now: August 30th, 2026 - 1:33 AM
