> 3sgte Japan vs Euro ECU-wiring, Interchangable?
post Mar 3, 2014 - 8:41 AM
skogs
Joined Apr 19, '08
From Norway
I'm swapping a 3sgte from a rhd st205 to a lhd st205. My mechanic says that the wiring in my car has been tampered with, and is useless. Is it possible to use the entire ecu-wiring harness from the rhd if i just extend the cables a bit?
This is the problem:
This post has been edited by skogs: Mar 3, 2014 - 8:48 AM
post Mar 3, 2014 - 9:37 AM
mkernz22
Joined May 10, '10
From MA
QUOTE (skogs @ Mar 3, 2014 - 8:41 AM) *
Yes, you can extend the wiring and use it. Stick with the JDM ecu too cause you get a few more HP out of it because of the tune on the ECU
post Mar 29, 2014 - 12:07 PM
skogs
Joined Apr 19, '08
From Norway
Can i simply replace my stock ECU with the jdm ECU? Without any further adjustments?
post Mar 29, 2014 - 12:15 PM
mkernz22
Joined May 10, '10
From MA
QUOTE (skogs @ Mar 29, 2014 - 1:07 PM) *
You should be able to since it's for the same engine.
Not sure if someone else can chime in on this?
Lo-Fi Version Time is now: July 30th, 2026 - 7:54 AM
