Mar 5, 2014 - 10:51 AM
![]() Enthusiast ![]() ![]() ![]() Joined May 13, '06 From Kaimuki, HI Currently Offline Reputation: 10 (100%) |
Ok..look through this thread if you want to see my past attempts.
http://www.6gc.net/forums/index.php?showto...chometer+signal In short, my temp gauge and tach gauge don't work anymore. The options I've thought about are (1) getting SS III gauges off ebay for $150 and swapping the odo, or (2) getting a cluster from an early 00's toyota car that has coil-on-plug setup from the factory and putting that tach in with my gauge face (may not be accurate). Option 1 seems more doable, but I don't want to spend the $150 on gauges (PLUS I don't know if my wire harness connects to the SS III gauges, can someone tell me???) If so, all I would need to do is connect the tach wire from my Autronic ecu and configure, correct? Hopefully the wire connectors aren't needed. Option 2 seems cheaper if I can find working used gauges on ebay. I'm concerned about the tach signal not lining up with the correct numbers (since I would have the moving parts from the donor car and the gauge face from mine). The only other downside would be that I still have to fix my temp gauge. My only questions are about the interchangeability of the SS III gauges with the celica (manual trans GT convertible). And if anyone knows what other toyota models with coil-on-plugs would be good candidates for using the RPM gauge in the celica. -------------------- -Jay
95 GT conv. project car: Manual, Gen III 3sgte, JN pisons, Eagle rods, overbore, crank knife-edged, crank scraper, ARP head/main/flywheel, Autronic EMS, Haltech Dual Wideband O2 controller, Audi 1.8T individual coils, FMIC and SSQV BOV, 3" downpipe, 3" ultra-high-flow cat, 2.5" Borla muffler, +other 01 S2000: FMIC, Haltech EMS, Haltech wideband, 570cc inj, forged pistons/rods, sleeved block, 5 angle valve job, ported and polished 02 R6, all stock, except for braided stainless brake lines, frame sliders, and adjustable brake/clutch leve |
match220 aftermarket ECU, coil-on-plug setup, swap tach assy or SS III cluster? Mar 5, 2014 - 10:51 AM
richee3 You could use a Dakota Digital or MSD tach adapter... Mar 5, 2014 - 6:44 PM
match220 QUOTE (richee3 @ Mar 5, 2014 - 1:44 ... Mar 5, 2014 - 7:12 PM
Smaay the 7th gen gauges will not work its a single piec... Mar 7, 2014 - 12:43 AM
match220 QUOTE (Smaay @ Mar 6, 2014 - 7:43 PM... Mar 7, 2014 - 7:27 AM
Sunny Hi,
i had the same problem with the gen.4 3S-GTE ... Mar 7, 2014 - 12:20 PM
match220 [quote name='Sunny' date='Mar 7, 2014 ... Mar 7, 2014 - 1:54 PM
match220 So I got a little creative the other day and figur... Mar 9, 2014 - 8:49 AM
Sunny Hi,
that resistor just lowers the ampere on the i... Mar 9, 2014 - 10:44 AM
match220 HEY!!
So I found this ebay seller selling ... Mar 9, 2014 - 10:50 AM
richee3 Yeah, the SS-III's were offered with the same ... Mar 9, 2014 - 12:31 PM
match220 QUOTE (richee3 @ Mar 9, 2014 - 7:31 ... Mar 9, 2014 - 6:39 PM
match220 st205 gauges for $13 on ebay with $20 sh... Mar 10, 2014 - 2:23 PM
richee3 Yeah, it would be a BEAMS engine. The wideband rea... Mar 10, 2014 - 6:50 PM
match220 QUOTE (richee3 @ Mar 10, 2014 - 1:50... Mar 10, 2014 - 9:22 PM![]() ![]() |
| Lo-Fi Version | Time is now: September 1st, 2026 - 8:30 AM |
