Mar 11, 2014 - 9:54 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 12, '07 From Lancaster, Pa Currently Offline Reputation: 35 (100%) |
I rebuilt my gen ii 3sgte over the fall. New Toyota oem gaskets, machine work, new turbo etc. assembled it with engine lube and ran Mobil conventional 10-30 for the first 1500 miles. I recently did a Mobil synthetic 10-30 oil change and oil has been leaking from I between the engine and Trans (very sizable about of oil leaks when car is running). What caused this leakage? I would think if the gasket was seated incorrectly it would leak from day one. Any input is appreciated!
garin 3sgte rear main seal Mar 11, 2014 - 9:54 AM
Tigawoods oh boy... Mar 11, 2014 - 10:26 AM
garin Possibility that crankcase pressure was the cause?... Mar 11, 2014 - 10:45 AM
garin false alarm! it was the passenger axle seal. t... Mar 11, 2014 - 6:41 PM
lagos QUOTE (garin @ Mar 11, 2014 - 11:45 ... Mar 12, 2014 - 9:58 AM
Neon90424 a nice breather filter and a cheap catchcan you ca... Mar 12, 2014 - 12:28 PM
Special_Edy Get the Timkin seal from autozone. The borg-warner... Mar 12, 2014 - 1:33 PM
garin I ended up buying Toyota oem axle seals... I work ... Mar 12, 2014 - 2:26 PM![]() ![]() |
| Lo-Fi Version | Time is now: April 16th, 2026 - 5:48 PM |
