> TMIC removal
post Mar 16, 2014 - 3:14 PM
insanescotsman
Joined Aug 15, '13
From falkirk,scotland
hi im just wondering how you remove the TMIC on a st205?. thanks
Replies (1 - 5)
post Mar 17, 2014 - 12:07 PM
Malhar95
Joined Jul 5, '09
From Katy/houston
QUOTE (insanescotsman @ Mar 16, 2014 - 4:14 PM) *
Not sure if it's the same, but for my st185 swapped Celica, here's what I do:
Remove 4 bolts to take the cover off, and then I think there are 2 or 3 bolts that hold the ic to the motor. (It's been a while so maybe off on numbers)
Then loosen the hoses from the throttle body and turbo and just wiggle it till it's free.
I found it easier if I just remove the throttle body inlet directly. Makes it easier to pull out.
Hope this helps
post Mar 17, 2014 - 12:20 PM
insanescotsman
Joined Aug 15, '13
QUOTE (Malhar95 @ Mar 17, 2014 - 12:07 PM) *
Hope this helps
cool so its not attached to the other radiator at all its a contained system? as in if i take the top mount off and the radiator then itll all come out without messing with the engine coolant system?
post Mar 17, 2014 - 12:49 PM
mkernz22
Joined May 10, '10
From MA
why do you need to take the radiator off? There's two different coolant systems with the GT4's. The engine which goes to the radiator and the one for the topmount IC.
post Mar 17, 2014 - 1:03 PM
enderswift
Joined Jul 12, '08
you do not need to disconnect the water lines running from the top-mount to the heat exchanger. You can simply loosen the three bolts holding the top-mount to the engine (one on the passenger side, two on the driver side on a bracket), loosen the rubber couplers coming from the turbo and throttle body, wiggle the turbo coupler fee, and swing the intercooler toward the drivers side. No need to deal with coolant.
everything I just wrote assumes LHD.
post Mar 17, 2014 - 4:14 PM
insanescotsman
Joined Aug 15, '13
QUOTE (mkernz22 @ Mar 17, 2014 - 12:49 PM) *
cool so there 2 different systems? im putting a frontmount on so ill need to replace the whole deal.
Lo-Fi Version Time is now: June 21st, 2026 - 10:26 AM
