Mar 30, 2014 - 3:15 PM
Enthusiast Joined Jan 11, '10 From twin cities, mn Currently Offline Reputation: 0 (0%) |
I have a wiring harness built by Tweak'd Performance. I know that a few of you guys on here have ordered harnesses from Tweak'd and/or have better knowledge of how this works. I am not able to get power to the car. I have been instructed to connect the following:
CEL goes go your II1 body plug pin 7 tach goes to II1 pin 3 OIl goes to II1 pin 2 Temp goes to II1 pin 10 Reverse (red) goes to II1 pin 9 Reverse (black) goes to II1 pin 12 I haven't been able to figure out how to wire the ign hot wire, the spd wire, and the starter wire. I have connected the starter wire to a thick black wire I believe is connected to the starter and wired the fuel pump wire to a thick blue wire with black stripe that is on one of the body connectors. I did a little research and was able to find that the fuel pump is supposed to be connected to the positive wire connected to the fuel pump, but im not sure I have the right one. I'm not sure where to attach the following: http://i109.photobucket.com/albums/n80/dum...aj/IMG_5490.jpg http://i109.photobucket.com/albums/n80/dum...aj/IMG_5494.png http://i109.photobucket.com/albums/n80/dum...aj/IMG_5491.jpg Im thinking the orange one with a fuse attached to it is suppose to go to the Positive terminal on the battery. There is a ring with multiple brown wires connected to it that I'm guessing I should ground somewhere and then there is a plug that I don't know where it goes at all. Any help would be appreciated. This post has been edited by stinkyfeet: Mar 30, 2014 - 3:41 PM |
stinkyfeet 4age 20v wiring harness help Mar 30, 2014 - 3:15 PM
Smaay whats your email, ill send you the EWD for whateve... Mar 31, 2014 - 8:28 AM
stinkyfeet QUOTE (Smaay @ Mar 31, 2014 - 8:28 A... Mar 31, 2014 - 11:20 AM
Smaay sent Mar 31, 2014 - 3:01 PM
stinkyfeet QUOTE (Smaay @ Mar 31, 2014 - 4:01 P... Mar 31, 2014 - 3:40 PM![]() ![]() |
| Lo-Fi Version | Time is now: September 14th, 2026 - 4:12 PM |
