Apr 3, 2014 - 4:42 PM
Enthusiast ![]() Joined Jul 7, '06 From usa Currently Offline Reputation: 0 (0%) |
Hey guys. I just bought back my old celica and have been busy working on it. The exhaust was so loud on this beast that I couldn't hear the rattle until I just replaced my Hi-flo cat with a new quieter and deeper sounding one. Now I can here myself think.
This is the problem - I have a rattle coming from the rear passenger side. I thought it was the hatch - it is not. It is not anywhere in the trunk area. I've narrowed it down to somewhere between the b-pillar and below the rear quarter window. Any thoughts? It is driving me NUTS. I can only here it when I hit a bump. It sounds like the hatch is shaking. But it is not the hatch. I hope 1 of you knows exactly what it is. thanks. |
Apr 4, 2014 - 12:01 PM
Wow so I guess this is not a common issue
Apr 4, 2014 - 1:28 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 2, '07 From Berlin, WI Currently Offline Reputation: 18 (100%) |
could be a lot of things.
there's a few threads on here if you look for them. endlinks and sway bar bushings seems to be a common answer. if not, could really be anything like loose plastics or a screw. -------------------- ![]() *1997 Celica ST - 3SGE Greytop BEAMS *1977 Celica RA29 - Classic Cruiser *2005 Matrix AWD - dedded but still hanging around like a ghost 2019 Rav4 XLE Premium - Sports mode is fun. |
Apr 4, 2014 - 5:36 PM
could be a lot of things. there's a few threads on here if you look for them. endlinks and sway bar bushings seems to be a common answer. if not, could really be anything like loose plastics or a screw. The bushings are only a few months old, but I'll check them out. It sounds like it's coming from inside the body. I removed all the panels and found nothing. Just thought I was looking in the wrong spot. Thanks again. I'll check those 2 things out. |
Apr 5, 2014 - 7:52 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 31, '11 From Rochester, NY Currently Offline Reputation: 5 (100%) |
Jack it up and grab your rear strut. Try shaking it. Also, check your jack... The scissor jack will make all kinds of noise if it's loose.
-------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. ![]() *ASE Certified General Manager |
Apr 5, 2014 - 1:23 PM
Jack it up and grab your rear strut. Try shaking it. Also, check your jack... The scissor jack will make all kinds of noise if it's loose. checked it and it al looks good. This is driving me nuts. It sounds like something broke off above the rear speaker. the car is clean and everything is tight. I'm going to have to rip all the panels off and probably the rear seat too. Thanks guys. If I figure this one out, I'll let you know what it was. |
Apr 7, 2014 - 2:47 AM
Enthusiast Joined Aug 24, '13 From Vancouver area Currently Offline Reputation: 0 (0%) |
rear suspension arm bushings / Trailing arms
Apr 8, 2014 - 11:20 AM
Enthusiast ![]() ![]() Joined May 16, '11 From YYC Currently Offline Reputation: 0 (0%) |
I have the same issue, after I have replaced my rear seats...im guessing its the rear seat latch....im going to tackle this issue this weekend....
Apr 11, 2014 - 9:20 PM
I have the same issue, after I have replaced my rear seats...im guessing its the rear seat latch....im going to tackle this issue this weekend.... Let me know how it turns out. I can't get to it until next week. I had a mechanic check out the whole car and he has no clue either. |
Apr 12, 2014 - 4:46 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 18, '09 From Orlando Currently Offline Reputation: 8 (100%) |
Slightly loose spoiler bolts?
'90 MX-5 Mariner Blue '93 MX-5 LE '07 Kawasaki Eliminator 125 silver '15 Optima Grey '04 206 GTi silve |
Apr 12, 2014 - 5:00 PM
Enthusiast ![]() Joined Apr 21, '13 From california Currently Offline Reputation: 2 (100%) |
Check the caliper to see if they are lose. Move them side to side
I had a noise everytime i would hit a bump it would rattle. Turned out to be the slider pins. |
Apr 12, 2014 - 11:28 PM
Its a rattle can in the trunk
Apr 13, 2014 - 10:37 AM
Apr 13, 2014 - 10:40 AM
Check the caliper to see if they are lose. Move them side to side I had a noise everytime i would hit a bump it would rattle. Turned out to be the slider pins. I checked it out yesterday. I had to re-torque my new wheels. So far it looks good, everything was nice and tight. I'm now thinking that it has something to do with the should strap of the seat belt. Sounds like it's right in that area. I'm going to strip the whole back out of it this Friday. Hopefully I'll find it then. |
Apr 20, 2014 - 3:33 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Mar 3, '05 From Richmond, B.C. Currently Offline Reputation: 0 (0%) |
Check the parking brake assembly. Inside the drum the shoes are held in place by hold-down springs. The springs are compressed by being mounted on pins. If the straight pin broke, or the curved pin straightened, the shoe is free to move and rattle against the backing plate.
| Lo-Fi Version | Time is now: September 11th, 2026 - 7:05 PM |
