> wiring 12v sockets.
post Apr 12, 2014 - 11:11 AM
MisterRay
Joined Jun 24, '12
From Birmingham
back again with a quick Q.
iv ordered a couple of these 12v sockets for the car
and will be installing them both in the blank spot here
my question is where would be the best/easiest place to get power for these without causing interference or problems to the rest of the car? need the power to switch on/off when the car switches on/off
my cig lighter socket has been disabled as i am currently running my heated seats AND my floor well leds from the cig lighter wiring and dont want to wire anything else towards that side so wont consider that an option. im also going to be using wago blocks to rewire anything i cut into as i cant be bothered to solder anything and T taps are crap.
any help would me much appreciated.
"whoever said progress was a slow process... was probably talking about me"
post Apr 12, 2014 - 12:21 PM
The_enD
Joined Apr 12, '13
Run a single wire from your battery. Your chassis will be the ground.
I don't see why you would need the power to go and off with the car. It's a socket after all.
Wouldn't hurt to fuse the wire too.
post Apr 12, 2014 - 12:48 PM
MisterRay
Joined Jun 24, '12
From Birmingham
QUOTE (The_enD @ Apr 12, 2014 - 1:21 PM) *
that sounds long lol was avoiding taking off too many parts. are there any other options? or is that my best bet. i already have sum in line fuses etc so thats sorted. i will give it a go as soon as they get delivered
post Apr 12, 2014 - 12:55 PM
The_enD
Joined Apr 12, '13
Just wire to the cig lighter, worst thing that could happen when you are using all the stuff wired is the fuse will blow.
post Apr 12, 2014 - 5:06 PM
MisterRay
Joined Jun 24, '12
From Birmingham
QUOTE (The_enD @ Apr 12, 2014 - 1:55 PM) *
iv decided to go with your first option and wire it directly to the battery. may not be the easiest option but probably the best for long term. out of curiosity, is there nothing near the steering wheel or kick panel that i could have drawn power from? i plan to install a mini tablet in my visor to use for reverse camera as i no longer can see through rear windows lol if i could tap into something there i can just reroute the wire through the kickpanel and pillar
post Apr 12, 2014 - 5:10 PM
The_enD
Joined Apr 12, '13
You got a bunch of wires in the kick panel, for the doors and what not. I am pretty sure there is power.
If you are not really experiences, don't mess with stuff around the steering wheel.
Lo-Fi Version Time is now: August 11th, 2026 - 10:10 AM
