> e153 internal compatibilities
post Apr 13, 2014 - 10:03 AM
olilaroche
Joined Feb 21, '14
From l'assomption, Québec
Does anyone know if i can swap internal parts of the e153 (gears, synchro, etc...) with the one from e154f?
My st205 front clip is only 63000 km so i would seriously consider using internal from my e154f to rebuilt a camry/solara e153 from a salvage yard. That would be easier than converting my e154f to fwd.
The car won't be used on the streets, only on race tracks.
This post has been edited by olilaroche: Apr 13, 2014 - 10:35 AM
post Apr 13, 2014 - 10:18 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
it woulc be easier to just use the take off the transfer case off the ST205 trans, use the solara cover plate and differential. dont try swapping all the gears around. just swap the differential and cover plate.
it would be easier to just use the take off the transfer case off the ST205 trans, use the solara cover plate and differential. dont try swapping all the gears around. just swap the differential and cover plate.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Apr 13, 2014 - 11:12 PM
olilaroche
Joined Feb 21, '14
So all i really have to do is putting the diff and cover plate from my e153. Simple enough!
Would the st205 front axels still fit or I'll have to go with hybrid axels using inner e153 and outer e154f axle
I'll probably take advantage of having it open to put a lsd diff in it.
post Apr 13, 2014 - 11:37 PM
careful with the axles, non lsdaxles are different than lsd. and some lsd are differents. so check it out before.
post Apr 14, 2014 - 12:19 AM
olilaroche
Joined Feb 21, '14
QUOTE (njccmd2002 @ Apr 13, 2014 - 11:37 PM) *
Yeah I've read that on another thread. But from my understanding, if i don't use the Toyota original lsd, i don't need to use mr2 turbo lsd axle.
So a Cusco or whatever other brand lsd should be alright. That's why i was asking if my st205 axles would fit or if i had to go with hybrid axels. Since the tranny is the e154f, i thought the st205 axels were fine without having to use hybrids.
post Apr 14, 2014 - 7:18 AM
olilaroche
Joined Feb 21, '14
QUOTE (Smaay @ Apr 13, 2014 - 10:18 PM) *
Are you talking about the plate #31116P ?
(This is from 98 camry e153)
This post has been edited by olilaroche: Apr 14, 2014 - 7:19 AM
post Apr 14, 2014 - 5:42 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
you could use the drivers side axle but the passenger side will need a MR2 axle and ST185 hybrid, look up converting to E153 trans threads
post Apr 14, 2014 - 7:12 PM
olilaroche
Joined Feb 21, '14
QUOTE (Smaay @ Apr 14, 2014 - 6:42 PM) *
Ok Thanks for the info! I thought because I could keep the modified e154f that both st205 axels could be used, but I realize now that the diff coming from e153 is changing things.
And for the cover plate, have I identified the right one?
post Apr 15, 2014 - 7:59 PM
team_omega
Joined Aug 14, '05
From St. Paul, MN(USA)
Yes the cover plate is the one you identified. Just use that plate and the diff and youll be good
post Apr 15, 2014 - 8:29 PM
olilaroche
Joined Feb 21, '14
Thank you very much everybody for your precious help! I'll probably need it again during the swap! wink.gif
Lo-Fi Version Time is now: July 30th, 2026 - 6:43 AM
