> e56 clutch/ flywheel kit
post Apr 19, 2014 - 8:59 PM
mi645
Joined May 23, '12
From northridge,CA
i need a new clutch for my 3d gen 3sge
i has an e56 transmission does anyone know where i can get a full kit?
which parts work for the e56? i have no clue?
i want a light flywheel also, ideas? would everything be the same as an mr2 gen 2 turbo motor?
post Apr 20, 2014 - 12:40 AM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
yes dude just buy a stock mr2/celica alltrac turbo set up. and get a lightweight flywheel if you like.
stickies are your friend:
http://www.6gc.net/forums/index.php?showtopic=89910%5bb
This post has been edited by BonzaiCelica: Apr 20, 2014 - 12:44 AM
post Apr 20, 2014 - 1:23 AM
mi645
Joined May 23, '12
From northridge,CA
e56 is not the same as e153
post Apr 20, 2014 - 1:29 AM
Box
Joined Feb 23, '12
From Warrior, AL
You don't say? rolleyes.gif Find a clutch kit for the SS-II or SS-III.
2001 Miata LS 5-speed
post Apr 20, 2014 - 8:08 PM
Rusty
Joined Nov 5, '07
From New Zealand
Flywheel same for any 3S-GE/GTE. Either lighten & balance the factory one or go chromoly flywheel over an aluminium one. I'm currently looking at getting a Jun lightweight, they do 2 weights.
Clutch cover is same for S54 & E56
Disc is a different story a S54 disc won't fit due to spline count from memory, so your looking into a E series disc
post Apr 21, 2014 - 12:56 AM
mi645
Joined May 23, '12
From northridge,CA
thank u rusty smile.gif i appreciate it, also this jun flywheel where do u purchase it?
post Apr 23, 2014 - 3:14 AM
Rusty
Joined Nov 5, '07
From New Zealand
there's a few places off yahoo auctions - if you have a middle man, online stores nengun & rhdjapan I know off the top of my head there are probably others too
post Jul 21, 2014 - 2:30 PM
KAOS
Joined Apr 18, '06
From Calgary, Canada
QUOTE (Rusty @ Apr 20, 2014 - 7:08 PM) *
When you say clutch cover, you mean "Pressure Plate", correct - if so, I think this statement is incorrect. If you have a 3S flywheel OEM/Aftermarket, you need a 3S pressure plate to mate to it. A 5S pressure plate has a smaller diameter and will not mate/line up with the 3S flywheel.
post Jul 21, 2014 - 11:23 PM
Rusty
Joined Nov 5, '07
From New Zealand
When you say 3S, do you mean 3S-GE or 3S-GTE?
post Jul 22, 2014 - 10:55 AM
KAOS
Joined Apr 18, '06
QUOTE (Rusty @ Jul 21, 2014 - 10:23 PM) *
Yup. They're both the same.
post Jul 23, 2014 - 11:56 PM
mi645
Joined May 23, '12
From northridge,CA
3sge, 3sgte clutch kit is different. if ur using an s54 the 3sge clutch kit is different from the 3sgte, if its an ss2 e56 trans then its the same as a 3sgte clutch kit. thats me assuming because, online e56 has different part numbers than a 3sgte like an mr2 or celica gt4 (st205) or (st185)
post Jul 25, 2014 - 10:42 PM
FORGMANN
Joined Dec 11, '04
From USA
QUOTE (mi645 @ Jul 23, 2014 - 11:56 PM) *
Like I told on text . 96 Rav4 flywheel / 3sgte clutch kit all you need . I have still . Fits perfect . Issue is flywheel - Rav4 FW has 3sge/5sge crank bolt pattern with 3sgte clutch mounting holes.
Old guy with the toys
95 ST205 WRC (the real deal)
94 MR2 HARDTOP Supercharged 2GR/6SPD 22 owned
post Jul 26, 2014 - 12:36 AM
mi645
Joined May 23, '12
From northridge,CA
what if i want a light flywheel which options do i have? or does it have to be rav 4 flywheel
Lo-Fi Version Time is now: May 20th, 2026 - 11:34 AM
