May 16, 2014 - 6:44 AM
I have seen several solutions, and i figured out a simple one for my liking, if you have access to a welder.
I used grade 8 nuts. These nuts are spot welded to the frame anyway, and the frame is what supports the engine weight. the previous owner had already drilled the holes for me, I just figured how to spot weld a nut in there, so when you tighten it, the bolt wont move. The bolt does not hold any weight. so I welded two nuts, to a flange... ![]() make sure your bolt is center and is appropiate ![]() I secured the flange with the bolt into the right position, to center it and to get it tight to the frame, where it would rest forever... ![]() once welded properly, i cut the excess metal.. ![]() did the second one and filled up the holes again, to prevent mice from finding a nest.. ![]() and shaved, and had the bolts ready to be used.. ![]() those nuts dont move and you can torque the bolts appropiately... I was in a hurry, so i could have welded the holes.... but oh well. This is not the best approach, but just one of many... -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
njccmd2002 How to: One solution to the ST passenger motor mount May 16, 2014 - 6:44 AM
playr158 Wow, this is actually a pretty good idea!
I... May 16, 2014 - 8:28 AM
The_enD Nicely done! May 16, 2014 - 1:53 PM![]() ![]() |
| Lo-Fi Version | Time is now: September 13th, 2026 - 9:08 AM |
