May 18, 2014 - 1:30 AM
Enthusiast ![]() Joined Oct 11, '13 From 103062 Currently Offline Reputation: 0 (0%) |
I'm looking to buy some lowering springs but I want to look lower then normal I baught some and it barely got lower hardly noticable got any suggestions? Thanks
May 18, 2014 - 1:43 AM
Enthusiast ![]() ![]() Joined Nov 18, '13 From FL Currently Offline Reputation: 2 (100%) |
sounds like u need coil overs than.. springs give you 1.5 and some say they get lower over time.
do you really need to get springs? if so what did u get that you happen to not like? -------------------- @floordauto |
May 18, 2014 - 1:46 AM
Suppose the real question is what springs did you buy?
May 18, 2014 - 2:16 AM
I got these they're alright but the height is almost the same if not the same
M2 Performance Toyota 90 91 92 93 94 95 96 97 98 99 Celica Lowering Low Springs by M2 P... http://www.amazon.com/dp/B003W2MQDM/ref=cm...d_c3fEtb10287MG |
May 18, 2014 - 3:04 AM
There's your problem, that's more or less along the lines of the garbage on eBay. Hopefully you can return them and get your money back and then buy some real springs from Tein or some other name brand.
May 18, 2014 - 5:10 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Sep 23, '12 From Australia Currently Offline Reputation: 4 (100%) |
![]() That's my car on Tein springs as suggested by box. I will also add, I lowered mine with the springs, and my passenger front shock bottoms out really easily. It was probably already dying before I lowered the car, but lowering it has killed it completely. If you keep the stock shocks they will be blown in no time, then you'll be up for x4 new shocks on top of the springs. Also, I don't think this is related to it being lowered but my top bearings are also now shot, they didn't make any noise before lowering and straight after lowering they started creaking and clunking... Well I hops it's the bearings... Not sure about over there, but here in Australia the difference between coil overs and springs+shocks is only $200-300. Coil overs also them give full dampening and height customisation, well making up for that extra outlay. -------------------- ![]() ------------------------------| White '94 Celica | Bought 11/05/12 | Sold 12/05/15 |------------------------------ |
May 18, 2014 - 1:22 PM
Over here the Megan EZ Street isn't much more than a set of new springs, struts, and mounts. So that might be another option.
May 18, 2014 - 4:47 PM
Can U send me some links for the coilovers please I was looking in ebay but they are like $1,000 that's why I was looking for some lowering spring so it would be cheaper.
May 18, 2014 - 6:49 PM
Lowering springs if you shop around are still around $200 cheaper, but if you want to drop more than 1.5" coil-overs are the only way to go. Here's the link: http://www.ebay.com/itm/Megan-Racing-EZ-Co...952&vxp=mtr
Can even try the best offer to save more money. -------------------- 2001 Miata LS 5-speed
May 18, 2014 - 6:50 PM
Approximated Lowering Rate: Approximately 2" Front & 1.75" Rear
Getting real springs or not.. He is not going to get any lower. Hate to see you buy another set and get the same height.. Buying tein or anyother brand will only improve the feel of the car.. Not much difference in the height.. Coilovers FTW.. -------------------- @floordauto |
May 18, 2014 - 7:52 PM
The problem lies within the fact the cheap springs didn't do what they were supposed to, even the 1.5" drop with the Tein springs is definitely noticeable.
May 18, 2014 - 11:41 PM
![]() Im pretty sure thats about the same height as stock. How much would I be looking at to buy some decent coilovers? The back looks is lower then the front but thats still the same as factory (rims were taking didnt like them too fat ,now back on steelies) This post has been edited by Yoni502: May 18, 2014 - 11:44 PM |
May 19, 2014 - 12:00 AM
Im pretty sure thats about the same height as stock. How much would I be looking at to buy some decent coilovers? The back looks is lower then the front but thats still the same as factory (rims were taking didnt like them too fat ,now back on steelies) First off.. Nasty set up.. that set up i would def get coil overs man.. You will never get it perfect with springs.. Cheapest coilovers are EZ Streets.. $699 <BUT BEST OFFER can be used.. http://www.ebay.com/itm/Megan-Racing-EZ-Co...952&vxp=mtr The Megan EZ Coilovers come with springs and struts so install is tits.. If you already got new struts you can try to find just the Coil over sleeves and springs.. but they are hard to come by. Search Ebay my friend..! -------------------- @floordauto |
May 19, 2014 - 12:27 AM
you think those would fit my car cause mine is a st not a gt? thanks
May 19, 2014 - 1:10 AM
![]() Did you install the front springs in the rear and rears in the front? Because my teins lower the front more than the rear but both Are very noticeable. -------------------- ![]() ------------------------------| White '94 Celica | Bought 11/05/12 | Sold 12/05/15 |------------------------------ |
May 19, 2014 - 8:46 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 2, '07 From Berlin, WI Currently Offline Reputation: 18 (100%) |
you think those would fit my car cause mine is a st not a gt? thanks it will fit. Just installed them on my ST last month. best and cheapest option for coilovers. I could go lower but the roads here suck.
-------------------- ![]() *1997 Celica ST - 3SGE Greytop BEAMS *1977 Celica RA29 - Classic Cruiser *2005 Matrix AWD - dedded but still hanging around like a ghost 2019 Rav4 XLE Premium - Sports mode is fun. |
May 19, 2014 - 10:13 AM
![]() Did you install the front springs in the rear and rears in the front? Because my teins lower the front more than the rear but both Are very noticeable. Yes I installed then on. All 4 wheels but no difference it just got alittle smoother but not lower. |
May 19, 2014 - 11:29 AM
you think those would fit my car cause mine is a st not a gt? thanks it will fit. Just installed them on my ST last month. best and cheapest option for coilovers. I could go lower but the roads here suck. ![]() Oh okay thanks I might save up for those thanks for the help |
May 19, 2014 - 12:00 PM
no problem. yeah, I had a set of TRD springs I was gonna put on but ended up selling those to fund these since springs + new struts + strut mounts and whatever else adds up to just a little bit less than the coilovers.
| Lo-Fi Version | Time is now: September 13th, 2026 - 2:39 AM |
