May 20, 2014 - 9:32 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Dec 3, '13 From Missourah Currently Offline Reputation: 0 (0%) |
still needs some attention but has a lot of parts
http://kansascity.craigslist.org/cto/4439340055.html 87 mr2 1987 AW11 Mr2 Mk1 T-Tops. Big port 4AGE- 20v individual throttle bodies w/ custom manifold, Wiseco 10.5:1 comp. .020 bore pistons, Crower billet rods, new balanced crank, cometic head gasket, head decked .020, 315cc injectors, EDIS ignition, APR Head studs & main studs & flywheel bolts, Crower stage 2 cams, Formula Atlantic valves, HKS valve springs, Fidanza adjustable cam gears, shimmed oil pump, tvis delete and port, spec stage 2 clutch and lightweight flywheel, NST pulley kit, POLYURETHANE engine mount, also brand new spark plug wires brand new NGK Spark plugs and recently put new Master an slave cylinders in it, Innovate MotorSports sensors, Also it's No longer has on stock ECU it's been Modified To run Megasquirt2 racing computer, does run when pushed started but needs tuned will need to be Towed away has 40k on motor but has 209xxx on the Body txt for more pictures IF Truly Interested, no low ballers wont take any less than $1,250 have way more than that put into the car alone an really don't want to sell, Drives pretty smooth with the D2 coilovers new brakes all the way around, and the T-Top seals are new, Keep In Mind This Is A Project Car! still needs some TLC, have no more funds for this car My loss your gain, just in case you don't know what a project car is like some people out their it is NOT a daily driver so dont ask, it is fully built just needs small amount of work to finish it up bit built for speed an power ![]() -------------------- Bust a Deal; Face the Wheel.
May 20, 2014 - 9:42 PM
You can't get the head off your 5S but you're going to jump into that? Not a good idea...
May 20, 2014 - 9:52 PM
O no I wasn't going to buy it, just for window shoppers
May 26, 2014 - 10:51 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Mar 7, '10 From Ft. Lauderdale Currently Offline Reputation: 9 (100%) |
doesn't a rear main seal require a full tear-down of the engine? Not really a "small amount of work" to finish it. but 1200 is a very fair price for what you're getting.
Jun 7, 2014 - 7:35 AM
Like most MR-2 any engine or trans work doesn't require removal of the drivetrain but you're insane if you don't....if the bolts will come loose. That gen sadly has '80's import syndrome, they rust so bad so fast unless you keep them in the desert.
| Lo-Fi Version | Time is now: September 13th, 2026 - 2:39 AM |
