May 27, 2014 - 10:35 AM
Enthusiast ![]() ![]() Joined Apr 24, '14 From Durham, NC, USA Currently Offline Reputation: 0 (0%) |
ADDED NOTE: I am not a trained auto mechanic; I try to DIY whatever I can to keep my 300,000 mile Celica happily running. Thanks to a wise comment below, I now see that making the statement 'my steering knuckle is bent' is oxymoronic on its face. The steering knuckle is made of cast iron and it is well known that cast iron does not bend (though exceptions exist). Cast iron acts more like a brick which cracks when a transverse force is placed between its two ends. Nonetheless, there exists a situation with my right front caliper mounting bracket, in conjunction with the disc, that causes it to seem very much like the mounting tabs on the steering knuckle are bent. I am seeking the true explanation for this (at least apparent) bending of a cast iron part. It would be great if some expert in front suspensions would stop by and explain my observations set out below, and pinpoint my problem. Until then, I dare not change the title of this topic; what cannot be is.
2nd ADDED NOTE: After much on-line research, I have been convinced that bending of the tabs (or ears) on steering knuckles is more common than most people believe, despite the fact that "cast iron doesn't bend." Not sure what that has to say about steering knuckle castings, or what exact metal they are made of, but evidently it does happen. See my posting near the end of this thread. 94 Celica ST Coup 1.8L Manual: Installed a new rotor (measures 0.986"; manual specifies 0.984" maximum). Rotor run-out minimized; much less than maximum. The caliper mounting bracket bolt tabs/ears on my right front steering knuckle are slightly bent toward the rotor (worst is the lower tab; 3/32 inch; shown in following photo). This causes the caliper mounting bracket to be misaligned so much that it interferes with my new rotor. ![]() It has severely scratched the last ¾ inch of the rotor (to the outer rim), during short test drives (less than 1000 feet). Of course it made a lot of noise, but it was the first time I had ever done a job like this and just wasn't aware of the severity of the problem. ![]() What is the best way to fix this problem? Should I attempt to bend the steering knuckle tabs? Is the steering knuckle a cast iron part? Should I die grind the proper alignment into the caliper mounting bracket surfaces where they meet the steering knuckle tabs? Should I buy and install a new steering knuckle; they cost around $200 and require a lot of work to install? This post has been edited by Langing: Jun 1, 2014 - 4:44 PM |
Langing Right front steering knuckle caliper mounting bracket tabs bent May 27, 2014 - 10:35 AM
playr158 The steering knuckle is cast iron....its HIGHLY un... May 27, 2014 - 2:00 PM
Langing Thank you for commenting. What you say is true. . ... May 27, 2014 - 2:56 PM
njccmd2002 looks to me like the rotor was not centered in the... May 27, 2014 - 9:17 PM
Batman722 QUOTE (njccmd2002 @ May 27, 2014 - 10... May 28, 2014 - 7:28 AM
Langing Not sure which pictures would help you the most. I... May 28, 2014 - 6:23 AM
Langing NOTHING ADDED 2:12 pm
Never can tell how long it... May 28, 2014 - 8:25 AM
Langing For pictorial completeness, and to share more obse... May 28, 2014 - 2:00 PM
njccmd2002 it looks like the rotor is dead center. can you ... May 28, 2014 - 3:13 PM
Langing QUOTE (njccmd2002 @ May 28, 2014 - 4... May 28, 2014 - 5:19 PM
Langing QUOTE (njccmd2002 @ May 28, 2014 - 4... Jun 5, 2014 - 3:35 PM
Langing Well, I WAS going to re-check the run-out today, a... May 29, 2014 - 9:39 PM
njccmd2002 If the rotor was bad, then it would wobble. I bet... May 30, 2014 - 10:29 AM
Langing QUOTE (njccmd2002 @ May 30, 2014 - 11... May 30, 2014 - 11:28 AM
MaskedMan If I remember reading correctly, ILoveMySilly97 ha... May 31, 2014 - 1:36 AM
Langing MaskedMan, thank you for the information. I scanne... May 31, 2014 - 4:41 PM
Langing ILoveMySilly97 did experience bending of an ear on... Jun 1, 2014 - 11:33 AM
njccmd2002 Get another knuckle. Dont try to bend and weaken ... Jun 1, 2014 - 3:50 PM
Langing QUOTE (njccmd2002 @ Jun 1, 2014 - 4... Jun 1, 2014 - 4:34 PM
Langing Picked up a 'new' steering knuckle at the ... Jun 13, 2014 - 7:51 PM
Langing Started a new thread in General to get help removi... Jun 18, 2014 - 12:42 PM
Langing Two other parts had to go through the chemical pro... Jun 18, 2014 - 1:17 PM
Langing Hey again. I was able to finish preparing the part... Jun 18, 2014 - 5:50 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 23rd, 2026 - 3:26 PM |
