> obd1 code 24 and 27, one thing after another...
post May 30, 2014 - 12:32 PM
cwong
Joined Jun 8, '13
From goldsboro, NC
Well seems like I fix one thing and then I get another.
So from what I have research. Code 24 is "Intake Air Temperature Sensor signal" and code 27 "Sub Oxygen Sensor signal"
Looking thru the forum don't see much just on these two codes. First code 24 seems like it's a vacuum leak? Or is there an actual sensor? Like that one that goes in the intake box or cai.
Code 27 no idea what a sub o2 sensor signal is.....
post May 30, 2014 - 12:40 PM
VavAlephVav
Joined Dec 3, '13
From Missourah
air intake sensor is the one that plugs into the air filter box. and a Sub-Oxygen sensor must be the second oxygen sensor in the exhaust. is that a Cali emission car? otherwise it must be the only O2 sensor that's in the exhaust right after the manifold.
This post has been edited by VavAlephVav: May 30, 2014 - 12:45 PM
Bust a Deal; Face the Wheel.
post May 30, 2014 - 1:05 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
yeah check the wiring for the sensor that plugs into the airbox through a rubber grommant.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post May 30, 2014 - 2:59 PM
cwong
Joined Jun 8, '13
From goldsboro, NC
Ya I saw the o2 sensor wire had been cut.
I have a short site intake and the hole for the wire rubs against the side of the reservoir for one of the mastercylinders? There's a cut in the wire but do I really need the sensor
post May 30, 2014 - 3:18 PM
VavAlephVav
Joined Dec 3, '13
From Missourah
the computer uses the entering air temp sensor and the O2 sensor to adjust the air/fuel mix, so you need them in order for it to work right.
I have this universal O2 sensor where it looks like they rigged the wire but that's the way you wire it past the stock plug in.
Lo-Fi Version Time is now: August 26th, 2026 - 1:43 PM
