> "whatever" swaped st205, which motor would worthy replace a 3sgte?
post Jun 16, 2014 - 4:55 PM
underground_desi...
Joined Dec 4, '11
From Greece
OK! I know it's not a forum friendly discussion but it's really common on other cars (rwd mostly)
you see sr rb 2jz and ls , bmw and mercedes v8 and v10s powered cars a lot these days.
Of course you can make that power of a 3s but it's not the best motor around.
Which swap would you do if you wanted big hp numbers and reliability for an AWD st205?
I've seen some v6 but they are fwd , and also a 4g (evo) swapped here in Greece.
I would like to hear some opinions and not the typical "stick with your 3s".
Replies (1 - 19)
post Jun 16, 2014 - 5:35 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Jun 16, 2014 - 6:20 PM
cardshark525
Joined Jan 12, '09
From State College, PA
Here... Buy this :
http://forums.modified.com/70/1039095/buy-...ngine-assembly/
Also you're from Greece so you should be aware of this:
http://www.youtube.com/watch?v=npJB2rz2MZA
Otherwise sure... **** it... dump $100k into the car and just go out and get a BMW S70 V12
This post has been edited by cardshark525: Jun 16, 2014 - 6:29 PM
post Jun 17, 2014 - 6:42 AM
underground_desi...
Joined Dec 4, '11
From Greece
QUOTE (Smaay @ Jun 16, 2014 - 5:35 PM) *
QUOTE (cardshark525 @ Jun 16, 2014 - 6:20 PM) *
Here... Buy this :
Thank you for your kind comments.
and just because I am from Greece and I know Dimitris drag celica for some years now and his opinion for the 3s motor I would like to hear some more serious thoughts about what other swaps have been done or could have been.
post Jun 17, 2014 - 2:25 PM
Malek
Joined Jan 26, '09
From Los Angeles
Maybe you've seen the K20 swapped MR2? Yes it's rwd but I'd imagine the adapter plate would work the same for the E154F. Only problem I might see is the rear of the engine interfering with the transfer case..idk, just speculation.. http://www.huxracing.com/#!cannibal1/cco3
Thought about a drive train from an STi? haha The EJ isn't the *most* reliable for big power..but I'd much rather pull one of those out than my 3s..
I think the biggest problem you will run into (and why people go rwd) is finding an engine that will line up to the E154F (if you wanted to keep that trans, idk).
Or do a drive train swap from an IS-F. Do it..
This post has been edited by Malek: Jun 17, 2014 - 2:31 PM
post Jun 17, 2014 - 6:27 PM
plain and simple, you can put any engine you want. Most people here, dont talk about it because it cost money. If you have it, and like a challenge go for it.
there is a guy here doing a RWD conversion with a 3sgte engine. not that easy tough, but with money, and time and skills you can do it.
This is not your average, high skill, high coin, DIY fabricator forum. There are a few exceptions. Some of these guys are good.
But most wont think over the box, because the cost is high. a 3sgte is around 4000 usd, and thats with no body mods, so you can imagine. The MR2 guys are swapping 2gr and their cost is 7000 +++, so if you want a real RWD celica, the cost is going to be higher... lol
but the best engine to start a rwd will be a 2jz, but for the money you will invest, better buy a beat up supra and repair it. A black top beams is only 200 hp, same as redtop. So you see practicality comes into play, unless you must have a rwd celica to drag race it, i can guarantee you, no one will answer here, and this post will be locked...
post Jun 17, 2014 - 6:41 PM
richee3
Joined Jun 29, '08
From Denver
Not the most hp out there, but a 1UZ is a good option for a RWD setup.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Jun 17, 2014 - 6:49 PM
yup forgot that, but space will be tight... but yeah.. after seeing project Binky. (a 3sgte with awd mini). you can put anything in a car provided you have, skills, time and moolah
post Jun 17, 2014 - 7:40 PM
Box
Joined Feb 23, '12
From Warrior, AL
Well, there's the MZ family of V6 engines. Ehhh... Maybe the GR family could work out as well. Ehh, not much else in the S family you're really want. Anything else will mean some pretty extensive fabrication.
2001 Miata LS 5-speed
post Jun 17, 2014 - 7:53 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
1mz block 3mz heads
Forged internals
Add boost till happy
If you stay awd that is
This post has been edited by kurt95gt: Jun 17, 2014 - 8:02 PM
94 st hatch my daily driver
n
post Jun 18, 2014 - 2:36 AM
Box
Joined Feb 23, '12
From Warrior, AL
OMGZ KURT IS ALIVE.
post Jun 18, 2014 - 8:02 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
QUOTE (kurt95gt @ Jun 17, 2014 - 5:53 PM) *
1mz block 3mz heads
Forged internals
Other way around. 3MZ block with 1MZ heads. you would need serious mods to the 3MZ heads to put them on a 1MZ block.
post Jun 18, 2014 - 2:21 PM
Box
Joined Feb 23, '12
From Warrior, AL
I totally would be up for a twin turbo 3MZ/1MZ hybrid ST205.
post Jun 18, 2014 - 5:00 PM
underground_desi...
Joined Dec 4, '11
From Greece
problem is that these v6 are really hard to find here in Greece and even less mechanincs would put their hands on them
The K20 is a great motor as mentioned and since it's been swaped on mr2's that could be easier.
the f20 is a similar motor with potential and a couple 6-700hp s2000s are curently selling for 10.000 (that's less than buying the parts only)
Same and better prices goes with some vw audi seats. the 20vt engine is a common engine tha goes safly on the 500 mark. and most of these germans are dailys.
post Jun 18, 2014 - 7:03 PM
Box
Joined Feb 23, '12
From Warrior, AL
Can take the 3S-GTE into the 600's last I knew of. If it were me I'd just work with what's there unless the engine needed replaced anyway.
post Jun 19, 2014 - 7:15 AM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
2GR-FE, 3.5L V6, over 270 hp stock. If that wasnt enough you could try putting a 1GR crankshaft into it, that way it would be 4 liters. Bolt on supercharger makes it over 350hp.
Imagine what a little bit of boost and a standalone ecu could do on this engine, and it should bolt right up to your E154 bellhousing.
post Jun 19, 2014 - 2:00 PM
underground_desi...
Joined Dec 4, '11
From Greece
QUOTE (Special_Edy @ Jun 19, 2014 - 7:15 AM) *
does the 2GR really bolts right up to the st205 awd tranny?
Is there somone that did it?
post Jun 19, 2014 - 3:09 PM
Special_Edy
Joined Oct 29, '11
I dont think they have ever been mated, but the bellhousing bolt pattern is the same. They have been mated to E153s, so the only potential problem you would face is whether the transfer case would hit the block.
People who have mated a 1mz to an e154 said they had to grind some material off the block to get them to fit together, but there were also special castings of 1mzs that came with an awd gearbox (maybe an awd rx300?). There may be awd variants of the 2gr as well, noone really knows a lot about them since they are so new and expensive.
post Jun 19, 2014 - 3:51 PM
For something different and fun...335i twin turbo I6, or E92 M3 V8.
This post has been edited by SwissFerdi: Jun 19, 2014 - 3:52 PM
'90 MX-5 Mariner Blue
'15 Optima Grey
'04 206 GTi silve
post Jun 20, 2014 - 8:24 AM
Neon90424
Joined Jan 19, '11
custom build an engine out of 2 CBR1000 engines and add boost for a 12000 rpm boost monster.
Lo-Fi Version Time is now: August 22nd, 2026 - 11:40 PM
