Jun 26, 2014 - 10:45 PM
Enthusiast ![]() Joined May 8, '14 From Houston Currently Offline Reputation: 1 (100%) |
Hey guys im doing a 3SGE swap and when they pulled the engine out they plasma cut through the back bracket for the motor mounts. If anyone has a front/rear bracket they want to part with let me know.
Also im looking for a MAF for a 3SGE. Thanks. |
Jun 26, 2014 - 10:50 PM
It uses the same mounts as a 5S, unless you're running an E56 trans with the 3S-GE.
Jun 27, 2014 - 9:26 AM
Jun 27, 2014 - 3:29 PM
Enthusiast ![]() ![]() ![]() Joined May 23, '12 From northridge,CA Currently Offline Reputation: 3 (100%) |
how us a picture of the tranny, this engine comes with 2 different manual trannys. if its an s54 its same as stock 5s usdm trans, if its an e56 ur gonna have a hard time getting those brackets
Dec 5, 2014 - 11:56 AM
Enthusiast ![]() Joined Jun 1, '08 From STL Currently Offline Reputation: 0 (0%) |
It uses the same mounts as a 5S, unless you're running an E56 trans with the 3S-GE. Im using the tranny it came with, but they cut through the bracket for it, so the bracket is the same as well? Did you ever get this taken care of? I have a brand new OEM rear bracket P/N 12321-74321 for sale. I'm about to list it on ebay as I have had for years and never used it. I thought I'd check here in case anyone wants it..... |
| Lo-Fi Version | Time is now: August 26th, 2026 - 4:42 PM |
