> Help!! Smoking like its no tomorrow!, I need help to figure out what it is and how to fix it..
post Jul 4, 2014 - 9:27 AM
Tort1llaboy
Joined Nov 25, '13
From Norway
Hello.
My 7afe have been smoking blue smoke for some time now.. and the smell of oil is present almost all time (USE ALOT OF OIL!)... It smokes never when idle, only when i give it some trotle.
i have been thinking it may be the Valve seals, but it might be the piston rings aswell...
what is your opinion?
- Tort1llaboy   Help!! Smoking like its no tomorrow!   Jul 4, 2014 - 9:27 AM
- - Special_Edy   Piston rings most likely. You can try to do a pist...   Jul 4, 2014 - 11:03 AM
- - Tort1llaboy   i have done a compresion test and all the sylinder...   Jul 4, 2014 - 11:30 AM
- - lagos   A good way to tell if its your valve stem seals is...   Jul 4, 2014 - 12:09 PM
- - enderswift   compression rings might be alright, oil scraper ri...   Jul 4, 2014 - 12:10 PM
- - Tort1llaboy   Looks like a long weekend for me any one knows th...   Jul 4, 2014 - 12:17 PM
- - VavAlephVav   engine/transmission stickys http://www.6gc.net/fo...   Jul 4, 2014 - 1:03 PM
- - Tort1llaboy   dint find the size. but i got them the hard way f...   Jul 4, 2014 - 1:19 PM
- - Tort1llaboy   The order list is put in then New piston rings, ...   Jul 4, 2014 - 3:13 PM
- - Box   The 7A is NOTORIOUS for burning oil due to stuck r...   Jul 4, 2014 - 4:02 PM
|- - Tort1llaboy   QUOTE (Box @ Jul 4, 2014 - 5:02 PM) ...   Jul 7, 2014 - 5:06 AM
- - Special_Edy   O2 sensors and catalytic converters dont like oil   Jul 4, 2014 - 8:39 PM
|- - Box   QUOTE (Special_Edy @ Jul 4, 2014 - 8...   Jul 4, 2014 - 9:06 PM
|- - Bitter   QUOTE (Box @ Jul 4, 2014 - 9:06 PM) ...   Jul 5, 2014 - 2:06 PM
- - Box   If he can get it to where there's no visible s...   Jul 4, 2014 - 9:02 PM
- - Box   Take it out and clean it once a month if it still ...   Jul 5, 2014 - 2:28 PM
- - VavAlephVav   is burning a Quart per 1000 miles really within to...   Jul 5, 2014 - 2:50 PM
|- - Box   QUOTE (VavAlephVav @ Jul 5, 2014 - 2...   Jul 5, 2014 - 3:33 PM
- - Special_Edy   Its burning it in the combustion chamber which wil...   Jul 5, 2014 - 3:18 PM
- - Box   Ahh, see where I live they don't have emission...   Jul 7, 2014 - 7:38 AM
|- - Tort1llaboy   QUOTE (Box @ Jul 7, 2014 - 7:38 AM) ...   Jul 7, 2014 - 4:47 PM
- - VavAlephVav   always use new bolts. at least that is the manufac...   Jul 7, 2014 - 7:34 PM
- - Box   If it's valve stem seals anyway and not rings....   Jul 7, 2014 - 8:24 PM
- - Tort1llaboy   I have a new timing belt for it aswell was chekin...   Jul 8, 2014 - 8:55 AM
- - Special_Edy   If your valve stem seals were leaking it would puf...   Jul 8, 2014 - 11:34 AM
- - Tort1llaboy   yeah i have tools to do that just need the time.....   Jul 8, 2014 - 11:50 AM
- - Box   Valve stem seals can leak severely while running t...   Jul 8, 2014 - 1:37 PM
- - Tort1llaboy   the problem is that it have been doing this for ov...   Jul 8, 2014 - 3:06 PM
- - Box   What happens with the rings is that the oil contro...   Jul 8, 2014 - 3:44 PM
|- - Tort1llaboy   QUOTE (Box @ Jul 8, 2014 - 3:44 PM) ...   Jul 8, 2014 - 5:31 PM
- - Box   Do you have Seafoam available in stores? If so bu...   Jul 8, 2014 - 10:30 PM
|- - Special_Edy   QUOTE (Box @ Jul 8, 2014 - 10:30 PM)...   Jul 9, 2014 - 10:31 AM
- - Box   Yeah, I forgot to mention removing the EFI fuse an...   Jul 9, 2014 - 11:51 AM
- - Special_Edy   I wonder if carb cleaner would be good to use. Its...   Jul 9, 2014 - 12:51 PM
- - Box   Everything would probably flash rust like a son of...   Jul 9, 2014 - 1:20 PM
|- - Special_Edy   QUOTE (Box @ Jul 9, 2014 - 2:20 PM) ...   Jul 9, 2014 - 2:41 PM
- - Box   MMO and Seafoam is used in oil and fuel, so I don...   Jul 9, 2014 - 4:58 PM
|- - Special_Edy   QUOTE (Box @ Jul 9, 2014 - 5:58 PM) ...   Jul 9, 2014 - 5:21 PM
- - Box   They're kind of both.   Jul 9, 2014 - 9:19 PM
- - Tort1llaboy   I tryed the piston soak and it dint work... so now...   Jul 10, 2014 - 11:55 AM
|- - Box   QUOTE (Tort1llaboy @ Jul 10, 2014 - 11...   Jul 10, 2014 - 3:12 PM
- - msk59   I will be starting to re-ring and headwork on my 9...   Jul 10, 2014 - 12:57 PM
|- - Tort1llaboy   QUOTE (msk59 @ Jul 10, 2014 - 12:57 ...   Jul 10, 2014 - 1:11 PM
- - msk59   Thanks. I have not opened the engine yet. I have b...   Jul 10, 2014 - 2:56 PM
- - Tort1llaboy   are u rebuilding the engine or just the head?   Jul 10, 2014 - 2:58 PM
- - msk59   I will take the head off and get it checked by a m...   Jul 10, 2014 - 3:05 PM
- - Tort1llaboy   smart move... u might aswell change all the bearin...   Jul 10, 2014 - 3:11 PM
- - Special_Edy   The head will get cleaned when you have it resurfa...   Jul 10, 2014 - 4:56 PM
- - Box   Bore and stroke it while you're at it.   Jul 10, 2014 - 5:35 PM
|- - Special_Edy   QUOTE (Box @ Jul 10, 2014 - 6:35 PM)...   Jul 10, 2014 - 7:30 PM
|- - Box   QUOTE (Special_Edy @ Jul 10, 2014 - 7...   Jul 10, 2014 - 8:20 PM
- - VavAlephVav   Actually Smoking is not such a bad thing after all...   Jul 10, 2014 - 8:08 PM
- - msk59   Thank You all for wonderful help and tips. This is...   Jul 10, 2014 - 10:11 PM
- - Tort1llaboy   But abote the head bolts, i have spokent to a Toyo...   Jul 11, 2014 - 1:44 AM
- - Box   I always use new head bolts, you're already sp...   Jul 11, 2014 - 12:44 PM
|- - Tort1llaboy   QUOTE (Box @ Jul 11, 2014 - 12:44 PM...   Jul 11, 2014 - 1:04 PM
- - Tort1llaboy   i havent looked that good at the cylinders. focus...   Jul 11, 2014 - 1:20 PM
- - Box   Try finding a hardware store that has a large sele...   Jul 11, 2014 - 3:16 PM
|- - Tort1llaboy   QUOTE (Box @ Jul 11, 2014 - 4:16 PM)...   Jul 11, 2014 - 3:26 PM
- - Box   Try looking around the internet for information. ...   Jul 11, 2014 - 5:17 PM
|- - Tort1llaboy   QUOTE (Box @ Jul 11, 2014 - 6:17 PM)...   Jul 11, 2014 - 7:31 PM
- - Box   Wooo!   Jul 11, 2014 - 8:53 PM
- - VavAlephVav   when you test the head for warpage you put a metal...   Jul 11, 2014 - 10:58 PM
- - msk59   Very valuable information here in this thread. Edd...   Jul 11, 2014 - 11:10 PM
- - VavAlephVav   the shop that's going to do mine is nervous th...   Jul 12, 2014 - 8:24 AM
- - Box   Psssh, find a BEAMS or 1MZ to throw in there.   Jul 12, 2014 - 10:01 AM
- - Special_Edy   All you need is a celica oil pan and oil pump pick...   Jul 12, 2014 - 11:16 AM
- - Tort1llaboy   How do i upload pics?   Jul 12, 2014 - 5:26 PM
- - VavAlephVav   you need to upload them to a photobucket account, ...   Jul 12, 2014 - 6:54 PM
- - Tort1llaboy   this is what i figured of the valve seals   Jul 12, 2014 - 7:35 PM
- - Tort1llaboy   So far so good   Jul 14, 2014 - 9:52 AM
- - msk59   Excellent but more pictures and description, any t...   Jul 14, 2014 - 10:43 AM
- - Tort1llaboy   The valves ar now reseated and new valve seals are...   Jul 16, 2014 - 4:37 AM
- - msk59   No worries, thanks what chemical you used to make...   Jul 16, 2014 - 7:29 AM
- - Tort1llaboy   u can get the engine whit transmision out in abote...   Jul 16, 2014 - 9:08 AM
- - Special_Edy   Some tips- Did you lap the valves before reinstall...   Jul 16, 2014 - 11:48 AM
- - Box   +1 on engine assembly lube, valve lapping and orde...   Jul 16, 2014 - 12:09 PM
- - VavAlephVav   There are several bids on YouTube showing how to l...   Jul 16, 2014 - 12:14 PM
- - Tort1llaboy   yeah i lap/reaseated the valves. and i keept the v...   Jul 16, 2014 - 12:26 PM
- - Box   The assembly lube stays on the parts unlike regula...   Jul 16, 2014 - 2:05 PM
- - Tort1llaboy   yeah that what we found out. Molycoat its called t...   Jul 16, 2014 - 2:49 PM
- - Box   I've always used it. Besides you change the o...   Jul 16, 2014 - 2:56 PM
- - Special_Edy   On top of that a capful of oil in each cylinder an...   Jul 16, 2014 - 3:41 PM
- - Box   Yep. Then cross your fingers and hope it doesn...   Jul 16, 2014 - 3:52 PM
- - Tort1llaboy   now im just waiting for the main rod bearings and ...   Jul 16, 2014 - 4:54 PM
- - Tort1llaboy   Soon done whit the engine. Tought u guys liked a u...   Jul 24, 2014 - 5:13 PM
- - Box   Wooo, cleanliness.   Jul 24, 2014 - 8:20 PM
- - msk59   What chemicals did you use to clean the pistons?   Jul 24, 2014 - 9:16 PM
|- - Tort1llaboy   QUOTE (msk59 @ Jul 24, 2014 - 10:16 ...   Jul 25, 2014 - 5:47 AM
- - Box   Kerosene is another good cleaner.   Jul 25, 2014 - 1:02 PM
- - Bitter   It would not hurt at all to add a couple extra oil...   Jul 25, 2014 - 11:22 PM
|- - Tort1llaboy   QUOTE (Bitter @ Jul 26, 2014 - 12:22...   Jul 26, 2014 - 10:15 AM
- - msk59   What size socket to use on the head bolts 12 mm or...   Jul 29, 2014 - 12:11 AM
- - VavAlephVav   I think the head bolts themselves are Star tool so...   Jul 29, 2014 - 9:24 AM
- - msk59   I had a call in to my local Toyota dealer and they...   Jul 29, 2014 - 12:58 PM
|- - Tort1llaboy   QUOTE (msk59 @ Jul 29, 2014 - 12:58 ...   Jul 30, 2014 - 6:49 AM
- - Special_Edy   Normally a 12 point socket allows twice as many an...   Jul 29, 2014 - 3:20 PM
- - msk59   Well: Pulled the head last night and no problems. ...   Jul 30, 2014 - 8:01 AM
|- - Tort1llaboy   QUOTE (msk59 @ Jul 30, 2014 - 8:01 A...   Jul 30, 2014 - 9:39 AM
- - msk59   Yes, this car came with AC, power steering but no ...   Jul 30, 2014 - 12:16 PM
Lo-Fi Version Time is now: May 10th, 2026 - 2:09 PM
