> Fuel pump info needed
post Aug 2, 2014 - 7:17 AM
Fujifilm
Joined Jun 2, '14
From Cheshire
OK here goes, I am at the stage where I am going to scrap the car I am so sick of it. Have posted on another forum but had no luck so hoping someone can give me an idea.
The car is a 1995 convertible (uk) 2.0 gt manual which is the 3S-GE engine with 70,000 miles and full toyota service history.
The symptoms are, from cold it will hesitate but not always straight away, could drive half mile before it does it. When it does I can have my foot to the floor and nothing happens. Then it surges and the car will run perfectly. EXCEPT if trying to drive at 20 or 30 mph it runs rough like its in the wrong gear. Driving at 35 and above it runs perfectly, Just to add to the problem, occasionally if I reverse and stop the idle will fluctuate and stall.
Jumping the diag pins shows no faults!
So far I have changed complete throttle body with sensors from a car that was known to run perfectly.
Fuel filter, water temp sensor, air temp sensor, spark plugs, distributor cap, rotar arm, thermostat.
As far as I can tell all vacuum hoses look OK
I am stumped for ideas.
Help appreciated.
This post has been edited by Fujifilm: Aug 28, 2014 - 2:57 PM
Lo-Fi Version Time is now: August 27th, 2026 - 11:08 AM
