> cooling system help
post Aug 3, 2014 - 11:25 PM
littlelen95gt
Joined Aug 3, '14
From cottage grove, mn
Hey guys! I'm new to the forum and new to the celica. I was lucky enough to have a good friend of mine give me his 95 ST204 5S-FE. I replaced the battery and clutch master cylinder today and decided to start it up. I was sitting inside messing with the radio for maybe 20 minutes or so and I heard a pop. The whole top part of the radiator exploded off!!!!! Heat gauge was reading normal and the water pump was replaced before it was garaged for three years. Any idea what may have caused this? Any advice would help. I'm a diy kinda guy. Thank you!
This post has been edited by littlelen95gt: Aug 4, 2014 - 12:38 AM
Replies (1 - 6)
post Aug 4, 2014 - 1:12 AM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
Either a faulty radiator or bad radiator cap.
Replace both
post Aug 6, 2014 - 11:45 AM
IfWeChoose
Joined May 25, '13
From Charlotte, NC
Time alone can cause a radiator to go bad. It probably had a crack before it was stored and simply dried out even further. You can get yourself an aluminum radiator if you plan on keeping it for a while and never have that issue again.
post Aug 6, 2014 - 1:33 PM
Special_Edy
Joined Oct 29, '11
Yes the plastic on the tank deteriorates with time but if the cap is defective it can cause pressure to build until the radiator explodes.
post Aug 6, 2014 - 2:33 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
Be smart and by a metal one. Lol.
post Aug 8, 2014 - 12:11 AM
HaysoosKreesto
Joined Nov 4, '09
From Sacramento, California
Yup, what ^ they said. I found out that it's best to change out the coolant every 3 years and when you don't KABOOM! Now when mine blew up, I changed the thermostat prior and the coolant prior, but not the rad cap.
http://www.6gc.net/forums/index.php?showtopic=90284&st=0
As shown ^ here.
If I had known what a "healthy" rad cap looks like perhaps it would of been different and perhaps not. I changed out the stock rad and got an aftermarket from Autozone (yes it's metal Silly97) and she has been beautiful ever since.
post Aug 11, 2014 - 5:50 PM
littlelen95gt
Joined Aug 3, '14
Thanks guys new radiator and cap work great. I was just afriad there was an underlying problem that caused it. My friend did mention it needs a headgasket but it just burns oil. So far its about a quart every 500 miles. No blue smoke from exhaust just always smells like burnt oil and minor smoke from under the hood after extended driving.
Lo-Fi Version Time is now: August 27th, 2026 - 3:43 PM
