Aug 6, 2014 - 2:07 AM
Enthusiast ![]() Joined Nov 13, '12 From Sacramento Currently Offline Reputation: 0 (0%) |
Hi All,
I am leaking some transmission fluid at where the passenger axle meets the transmission. ![]() And I noticed the metal ring that was supposed to be at the end of the axle covering the seal inside the transmission was loose and separated like so ![]() So my question is the leak from the rubber seal? Or is that little ring on the axle supposed to keep the oil in the transmission? Should I replace the seal? Replace the axle? Or somehow make the metal ring sit in its proper place? ![]() Thank you very much! Any advice would be appreciated! |
1994whitecelicagt Easy question about Transmission and Axle ! Aug 6, 2014 - 2:07 AM
njccmd2002 remove and drain oil.
remove axle
replace rubber... Aug 6, 2014 - 7:16 AM
Special_Edy Fourtunately thats the easier seal to replace, the... Aug 6, 2014 - 10:10 PM
1994whitecelicagt Great! Thank you Special_Edy and njccmd2002. I... Aug 7, 2014 - 2:18 AM![]() ![]() |
| Lo-Fi Version | Time is now: July 29th, 2026 - 7:35 AM |
