Aug 19, 2014 - 11:16 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 29, '02 From Lake Orion, MI Currently Offline Reputation: 6 (100%) |
Say you rebuilt your 5SFE from the ground up.... and say... you have the kind of oil leak that would require approx 1 quart of oil to be added every hour (Endurance racing conditions).. Where would this leak be coming from?
- *Every* seal on the engine is new (inc. valve guides) - Most of the mess is on the transmission side of the engine / engine compartment - Removing the access plate? the back of the flywheel looks dry / I don't think it is the rear main seal Other interesting tidbits: - The PCV has been deleted and replaced with a little cone filter... should this be replaced with a catch can? - The EGR has been deleted and a large bolt has been used to block the port... has anyone deleted EGR and if so how did you do it? Is anyone running a proper oil pressure gauge? What are you getting? @ High RPM and high load and when we are full and cold - we are high (60-70 psi) As we warm up, it drops to 50 psi or so... and then we lose oil until things get very low... 40 psi or so. -------------------- -Mike
mjcoury@gmail.com Team Reynolds Style Celica Blog Celica Wiki It will take him a moment to realize that he's about to make a 180 degree turn at speed, but you will be ready for it. Brace for the g's, and fast heel-toe work. |
qatar11 If I were an oil leak... where would I be? Aug 19, 2014 - 11:16 AM
VavAlephVav People say the motor burns oil naturally, like a q... Aug 19, 2014 - 12:03 PM
enderswift I've had oil flow past the pressure sensor bef... Aug 19, 2014 - 2:37 PM
Syaoran My car is leaking under boost and I am sure it... Aug 19, 2014 - 10:26 PM
presure2 2 things i can think of mike.
#1, pcv is definetly... Aug 20, 2014 - 9:31 AM
qatar11 QUOTE (VavAlephVav @ Aug 19, 2014 - 1... Aug 21, 2014 - 2:42 PM
qatar11 Found it... under the plate that connects the engi... Aug 24, 2014 - 9:40 AM
Syaoran Welcome to the club. I'm about to get a new oi... Aug 25, 2014 - 9:34 AM![]() ![]() |
| Lo-Fi Version | Time is now: June 22nd, 2026 - 1:01 PM |
