Sep 1, 2014 - 12:15 AM
Enthusiast ![]() ![]() Joined Jul 27, '04 From Houston Currently Offline Reputation: 0 (0%) |
Hey guys. I went to the salvage yard this weekend and found a few celicas. One of the things I grabbed was a set of head light shims/gaskets. I was super excited that I found them and took them off so quickly that I can not recall EXACTLY how they are supposed to go back on. I have looked through the threads and even some of the multimedia pictures to see if I could figure it out, but I haven't had much luck.
Does anyone know exactly which way the shims are supposed to be located and how to install them? Thanks in advance. |
Sep 1, 2014 - 12:52 AM
Enthusiast ![]() ![]() Joined Aug 26, '11 From ventura, ca Currently Offline Reputation: 10 (100%) |
IIRC there is little silver clips that hold the rubber gasket pieces onto the light maybe 4 per light?
Sep 1, 2014 - 1:09 AM
I know there are silver clips for the low beam head lights. But I do not think there are any for the high beams. I should have been more specific in my request for information, but I am referring to the high beams. When I took them off, all I had to do was take them off... there were no clips. Main thing I am looking for is proper orientation.
Sep 1, 2014 - 1:40 AM
The high beam gaskets slip onto the bumper.
Sep 1, 2014 - 3:12 AM
Slip onto the bumper in which orientation? There is an "eye lid" side to the gasket. Almost like the "eye lid" portion is cut in half so it is either on top, or on bottom.
Sep 1, 2014 - 11:47 AM
Enthusiast ![]() ![]() Joined Aug 18, '11 From Cochranville, PA. Currently Offline Reputation: 6 (100%) |
Slip onto the bumper in which orientation? There is an "eye lid" side to the gasket. Almost like the "eye lid" portion is cut in half so it is either on top, or on bottom. From the rear forward. It may be necessary to remove the bumper to gain access. If it is at the junkyard just loosen the top bracket and pry the bumper far enough to start removal, it should be pretty easy. Installing them will require you to at least loosen all the nuts and bolts to gain access. Bumper to fender 10mm nuts are a pain and require you to partially remove the fender liners. |
Sep 1, 2014 - 12:48 PM
I'm following you now, I see what you're asking. This is the driver's side. You can see how the gasket was sitting before it was removed.
Sep 1, 2014 - 2:23 PM
Sep 1, 2014 - 2:29 PM
It's no problem.
| Lo-Fi Version | Time is now: August 27th, 2026 - 2:31 PM |
