Sep 2, 2014 - 2:50 PM
Enthusiast ![]() Joined Apr 19, '08 From Norway Currently Offline Reputation: 0 (0%) |
I currently have two seperate vacuum lines running from the engine bay and to a boost gauge and a boost controller inside the car. They are connected via two T-pieces spliced into the dump valve vacuum line. Could this cause a problem? The HKS barely makes a sound, instead there is a faint flutter-sound, too much stuff in the vacuum line maybe?
source | T-- 100 cm-- boost gauge | 5 cm | T-- 100 cm-- boost controller | 10 cm | HKS ssqv This post has been edited by skogs: Sep 2, 2014 - 2:53 PM |
skogs Vacuum lines Sep 2, 2014 - 2:50 PM
Smaay i would have all those on dedicated lines. When yo... Sep 3, 2014 - 1:26 AM
skogs I think i will remove the boost gauge since the co... Sep 3, 2014 - 2:42 AM
skogs Can i use this as the source for the boost control... Sep 3, 2014 - 5:47 AM![]() ![]() |
| Lo-Fi Version | Time is now: May 17th, 2026 - 11:48 AM |
