> Removing window trim
post Sep 6, 2014 - 6:45 AM
Noahwhite2014
Joined Jul 1, '14
From Hawaii
Im assuming you just pull the trim off... but I'm not sure honestly. My door won't close fully because the gap in my window trim got larger or something and pushed the bottom edge down... Long story short, i hit it with a rubber mallet to try push it back up so the door could close, and it bent a bit and then elsewhere on the trim popped out a bit. hit that spot a bit softer, still bent, and again even more areas just a bit far out so the window isn't sealing up against the rubber....
i just want to take it off and straighten it out a bit, then push it back on so the door can close again.
- Noahwhite2014   Removing window trim   Sep 6, 2014 - 6:45 AM
- - Spider77   Trim Removal Its pretty easy to do.   Sep 6, 2014 - 2:33 PM
Lo-Fi Version Time is now: August 28th, 2026 - 12:54 AM
