> Bluetooth sound + rear windshield wiper = random BLARING sound, Sometimes when I flash my high beams as well
post Sep 26, 2014 - 4:27 AM
Jeebus
Joined Apr 21, '13
From YYC
I installed a Kenwood KDC-BT858U deck this past summer and use the bluetooth on it along with my Galaxy S3 to play music. I first noticed the symptoms when I flashed my high-beams, and it occurred randomly when I flashed. The sound would be normal, and when I flashed, sometimes it would stay normal, sometimes it would BLARE the volume to the point of distortion. Now that it's pretty much winter season here (rain for 6 months), I've been using my rear wipers more, and I figured out tonight that when my rear wipers are on auto, the sound will blare randomly as well.
All I need to fix the sound from BLARING DISTORTION to regular volume is to pause the music for a few seconds, then unpause it again.
I'm not quite sure whether it could be a short somewhere in the wiring since I didn't splice into the steering column stalks, and it's happening over bluetooth. I haven't yet tried whether these symptoms happen if I'm listening to the radio or CD (I'll try tomorrow). My soldering skills aren't 100%, but I'll have to check that I properly sealed my splices as well when I get a chance to rip apart my console.
Any thoughts?
post Sep 27, 2014 - 3:39 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
Does it have a physical line in you can try? does it do this with CD or Radio sources?
post Oct 3, 2014 - 5:12 PM
Jeebus
Joined Apr 21, '13
From YYC
It does not happen when I use the radio/CD player and flash my high beams or use the rear wiper. kindasad.gif I will have to investigate further.
post Oct 3, 2014 - 6:28 PM
igpx12
Joined Jan 30, '14
From Cortland NY
Sounds like your bluetooth receiver is close enough to the wiring that receives the extra output for those things. Just as a simple troubleshoot, move the adapter if its a plug in one like mine is. If its a built in receiver then call Kenwood and inquire to it, worst they'll tell you to do is check your fuses in the vehicle.
1997 ST:Limitedly Green
This car is not about racing... This car is not about power or performance... It's purely about being cool.
post Oct 6, 2014 - 8:07 PM
Jeebus
Joined Apr 21, '13
From YYC
QUOTE (igpx12 @ Oct 3, 2014 - 6:28 PM) *
Ill try calling them. I also deduced that the issue ties in with my subwoofer wiring. I had a flat tire last week and had to remove my woofer from my trunk to get my spare, and I was driving around without the sub wired up for a few days. I tried to reproduce the symptoms the other night when it was raining to no avail. I may have to re-route the wiring to my sub. The Kenwood unit does not have a bluetooth adapter, it is built in.
Lo-Fi Version Time is now: May 17th, 2026 - 4:27 AM
