> Fenders won't come off?!, Im pretty sure i took all the bolts off...
post Sep 29, 2014 - 4:15 AM
Noahwhite2014
Joined Jul 1, '14
From Hawaii
So I've removed the bumper, corners, and headlights (no broken tabs luckily [knocking on wood]). I removed all the screws holding the fender to the wheel well liner and also the two bolts under the door part of the fender (as well as that plastic piece that goes around the edge in this area as well), the one at the top when the door is open, the 3 under the hood. Are there any others?! I tried to remove it, but it seems to be stuck in the middle section at the front as well as at the door area...
Im absolutely puzzled with this... as i cannot find any other screws or bolts....
Lo-Fi Version Time is now: August 29th, 2026 - 7:35 PM
