Sep 30, 2014 - 12:57 AM
Enthusiast ![]() Joined Oct 11, '13 From 103062 Currently Offline Reputation: 0 (0%) |
ive been having an issue with my car when it gets to normal temp and try to go on a steedy rpm it will start stuttering its mostly when i goto 2000 rpm and theres also a power lost when it does that and my second problem is when ever i go to third gear as soon as i let go of the clutch it ethier pop out or just grind them i have to take it out and put it back in 3rd in order to work if u know wat it could be let me know please and thanks
This post has been edited by Yoni502: Sep 30, 2014 - 12:58 AM |
Sep 30, 2014 - 8:14 AM
give the car a tune up for the sputtering, and it sounds like your syncros are going out on the trans.
Sep 30, 2014 - 3:10 PM
I did a tune up a while ago and it didn't stop it nd how would I be able to fix that?
Oct 2, 2014 - 10:11 PM
Enthusiast ![]() ![]() Joined Nov 18, '13 From FL Currently Offline Reputation: 2 (100%) |
I did a tune up a while ago and it didn't stop it nd how would I be able to fix that? How many miles? when you did the tune up, what exactly did you do? As far as the 3rd gear, you can try to change the manual fluid. I use syncro mesh and it did help my slight grind. Search the forum on that problem. Tons of info !! -------------------- @floordauto |
| Lo-Fi Version | Time is now: August 26th, 2026 - 9:28 AM |
