Oct 8, 2014 - 11:44 AM
Enthusiast Joined Jan 29, '14 From Los Angeles Currently Offline Reputation: 0 (0%) |
Hey I have a 3sgte 3rd gen on my Celica but I have a problem that's is not boosting stock psi is on 7-8 psi n I see that it might be cause the piping that is close or top of the exhaust manifold gets super hot n what I found online that soaking heat don't let the car get full boost. When the weather is really cold I can get close to 10 psi so what I'm thinking that that's my problem the soaking heat so I wanna see if I can use any other intake manifold ? I was thinking to do a custom on or see if that one on the 4th gen will fit. N hoping to find help here I'm new using forums n im in SoCal if someone close can help me get my car running 100%
Oct 8, 2014 - 11:57 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 12, '08 Currently Offline Reputation: 5 (100%) |
You probably have a boost leak. Or if your check engine light is on your car is in limp mode
Oct 8, 2014 - 12:03 PM
Oct 9, 2014 - 7:32 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Apr 17, '10 From U.P. michigan GO STATE Currently Offline Reputation: 3 (100%) |
You can spray carb cleaner over your vacuum lines while the car is idling. if the idle jumps up then you have a vacuum leak,which can also be a boost leak when under power. also if your check engine light is on it will be in limp mode like enderswift said.
![]() Celica: The name is derived from the Spanish word for "heavenly" or "celestial". Back-2-Back July COTM 15&16 |
Oct 9, 2014 - 9:30 PM
You can spray carb cleaner over your vacuum lines while the car is idling. if the idle jumps up then you have a vacuum leak,which can also be a boost leak when under power. also if your check engine light is on it will be in limp mode like enderswift said. Thanks I will do that n let u know what happen, n I did check for codes but when didn't make pause it was just flashing so I don't know if that is normal or means 0 codes |
| Lo-Fi Version | Time is now: July 28th, 2026 - 10:03 PM |
