Oct 10, 2014 - 7:33 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Apr 17, '10 From U.P. michigan GO STATE Currently Offline Reputation: 3 (100%) |
So this darn axle just will not come out on the left side of the st205. i thought i knew all the tricks of the trade from work but i soon learned that nothing was working. ive tried pry bars, hammers with pry bars, little bars big bars and just about every angle i can get at seeing as i can only get the car about 3 feet off the ground. im wondering if any of your magicians have any tips!
![]() Celica: The name is derived from the Spanish word for "heavenly" or "celestial". Back-2-Back July COTM 15&16 |
Oct 10, 2014 - 8:51 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 12, '08 Currently Offline Reputation: 5 (100%) |
Rent a slide hammer from advance auto. Buy a cv axle adapter from AutoZone if necessary. It will pop out in 10 sec
Oct 10, 2014 - 9:01 AM
would you happen to have a part number for that axle removal tool? i have a slide hammer from the dealership here but i couldnt find anything in toyotas extensive tools they give us for the axle portion.
Oct 10, 2014 - 9:33 AM
Oct 10, 2014 - 10:24 AM
Enthusiast ![]() ![]() Joined Jan 13, '12 From Georgia Currently Offline Reputation: 3 (100%) |
That's the one. Watch you Knuckles though. Weight distribution is also important as is what's behind you. I used one once and ended up laying on top of a Brake caliper that was behind me
This post has been edited by toyota123: Oct 10, 2014 - 10:25 AM -------------------- 97 Celica GT liftback DD/ project
96 corolla back up DD |
Oct 10, 2014 - 10:49 AM
hopefully this works, im already beat up from trying to use pry bars. im just not sure how im going to get that tool on the axle seeing as the opening is only like 2in when the axle is a lot bigger than that lol
This post has been edited by 4-eyed-freek: Oct 10, 2014 - 11:04 AM -------------------- It takes 8,460 bolts to assemble an automobile, and one nut to scatter it all over the road.
Oct 10, 2014 - 12:06 PM
You position it on the axle the slide the hammer in and secure the nut
Oct 10, 2014 - 12:17 PM
![]() like i said. the axle is to big. this is a picture from a Camry at work that has almost identical axle size. -------------------- It takes 8,460 bolts to assemble an automobile, and one nut to scatter it all over the road.
Oct 10, 2014 - 1:09 PM
Enthusiast ![]() ![]() Joined Aug 18, '11 From Cochranville, PA. Currently Offline Reputation: 6 (100%) |
Oct 10, 2014 - 1:22 PM
This^
Oct 10, 2014 - 1:23 PM
im really hopping that will be the case. otherwise im just not sure how im going to get this darn thing out.
Oct 10, 2014 - 1:33 PM
that adapter is designed to fit on the axle stub, not the tulip. you will most likely will not be able to get it into place while it's attached to the slide hammer. I usually squeeze the adapter between the tulip and transmission before coming in and threading the slide hammer onto it. A more labor intensive but sure-fire method involves lowering the subframe about 2 inches to open up some extra space
This post has been edited by enderswift: Oct 10, 2014 - 1:34 PM -------------------- ![]() |
Oct 12, 2014 - 3:37 AM
Enthusiast ![]() ![]() ![]() Joined May 23, '12 From northridge,CA Currently Offline Reputation: 3 (100%) |
i know another way in case u dont get it out. fairly simple.
if u have the right side axle out, simply grab a long screw driver flat head, thing 1 and slide it thru the hole make sure its contacting the other side and just hit it with a hammer and it will pop right out. |
Oct 12, 2014 - 9:52 PM
Could not get it out, I'm just going to trailer it to work. No sense to wasting time on a garage floor when I have everything you can ask for at a dealership lol. Btw future gt4 owners the axle removal tool does not work. Will not fit in any way shape or form. Axles are much bigger than what opening of the tool.
Oct 12, 2014 - 10:22 PM
Make a noose of steel cable and attach it to the slide hammer by a couple nuts and a smaller loop. Pull it taught and give it a couple hard slides, it should pop it.
| Lo-Fi Version | Time is now: September 14th, 2026 - 7:51 PM |
