> Subframe: Will the front subframe of a '95 Toyota Celica fit the a
post Oct 11, 2014 - 10:00 AM
xm0rgu3x
Joined Jul 15, '11
Hey guys,
The front subframe of my 1996 Toyota Celica 7afe is rusting and I would like to replace it. I have found the same part from a 1995 and was wondering if it would fit? I assume that they would since they are both from the 6th generation, but I would like some feedback before I start working on it.
Any feedback is greatly appreciated!
Thank you
post Oct 11, 2014 - 11:43 AM
mkernz22
Joined May 10, '10
From MA
I am 99.99% sure that it should. I don't see why it would be different
post Oct 11, 2014 - 11:14 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
yep should fit
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Oct 13, 2014 - 3:59 AM
igpx12
Joined Jan 30, '14
From Cortland NY
It will fit, only difference from 94-95 and 96-99 was the adaptation to OBDII but that only concerns the motors. Even if the replacement was from a 5S equipped 6GC it would still work being that your only difference then is the motor mounts.
1997 ST:Limitedly Green
This car is not about racing... This car is not about power or performance... It's purely about being cool.
post Oct 13, 2014 - 9:46 AM
mgnt232
Joined Mar 16, '09
QUOTE (igpx12 @ Oct 13, 2014 - 4:59 AM) *
Long story but I bought what I thought was an ST front subframe, turned out to be from a GT. Not a good way to go. The way the steering rack mounts, or the rack itself (one of the two) is different between the ST and GT. You have to make a custom bracket for it, and its never quite the same lol.
But all the ST subframes will work.
- 6GC for Life -
>Semper Fi<
1994 Cupra :p 3sgte
1995 Celica ST DD
1969 Chevelle SS
alllll balls. P2 approved!
post Oct 13, 2014 - 11:00 AM
sandusky1977
Joined Oct 3, '10
From Lansing, MI
Oh,. I had never even thought about this, but I'm planning on swapping the entire front end from a 99 GT in to a 95 ST including manual transmission conversion, brakes, etc.... etc... etc.. and a V6,.
I'm guessing this isn't going to be a problem if I swap everything, steering rack, trans, etc?
post Oct 13, 2014 - 5:44 PM
richee3
Joined Jun 29, '08
From Denver
The steering rack is different but ToyoDIY shows the same part number between my 98 GT and a 95 ST.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Oct 13, 2014 - 9:59 PM
mgnt232
Joined Mar 16, '09
QUOTE (richee3 @ Oct 13, 2014 - 6:44 PM) *
Well I'm just saying from my experience. Bought a front subframe for the 'reliable' Jim, said it was from an ST. Every bolt mounted up the same with the exception of the 2 that mount the steering rack. I assume I still have pics somewhere I'll try to find them tonight.
- 6GC for Life -
>Semper Fi<
1994 Cupra :p 3sgte
1995 Celica ST DD
1969 Chevelle SS
post Oct 14, 2014 - 5:48 AM
richee3
Joined Jun 29, '08
From Denver
I believe you. smile.gif I was just saying that ToyoDIY shows the same part number (51201-20300) and diagram for all of the USDM models. The ST202, Carina, Corona, and Curren also share the same subframe if I expand the search outside of the U.S. The steering rack also shows the same part number for USDM Celicas and some European Celicas (44250-20640.)
1998 Celica GT-
BEAMS Swapped.
post Oct 14, 2014 - 10:23 AM
mgnt232
Joined Mar 16, '09
QUOTE (richee3 @ Oct 14, 2014 - 5:48 AM) *
Yeah I probably got the one that was different. This Thread is from years ago when I replaced it.
Left from my ST, right I assumed from a GT since it was different but never looked too much into it. Maybe it was from a 205, or RHD?
The right ones mounting points are a few inches apart in comparison. Everything else mounted perfect
Had to make a bracket to extend to the steering rack. Works perfect, just kind of a pain.
This post has been edited by mgnt232: Oct 14, 2014 - 10:25 AM
- 6GC for Life -
>Semper Fi<
1994 Cupra :p 3sgte
1995 Celica ST DD
1969 Chevelle SS
Lo-Fi Version Time is now: September 14th, 2026 - 9:04 AM
