Oct 14, 2014 - 6:47 PM
Enthusiast ![]() Joined Jul 11, '12 From Pearl Currently Offline Reputation: 0 (0%) |
I have a 4th gen an the timing belt ripped an jumped a couple teeth an got that fixed an in time an now it's running rich an dumping straight fuel! Could that be from stuck injectors? Anyone had this problem before?
Oct 19, 2014 - 12:31 AM
how do you know its dumping fuel? do you have a wideband O2?
I have seen 1 instance with an injector stuck open and it filled the cylinder with gas and hydrolocked the engine. -------------------- 2001 Celica GT-S Turbo
Oct 19, 2014 - 3:45 PM
Yea I have a wide band an it's max rich an it's coming out of the exaust!
Oct 22, 2014 - 5:48 PM
![]() Enthusiast Joined Jul 1, '12 From Stanhope, NJ, USA Currently Offline Reputation: 0 (0%) |
Yea I have a wide band an it's max rich an it's coming out of the exaust! Open your ECU and check for blown capacitor. This has happened to us before. Try swapping out the ECU to check real easily. We had a bad capacitor and one of the injectors was getting pegged open by the ECU. Swapped ECUs and job done. Good luck. Let us know if you need anything GEN4. It's what we do. www.primemr2.com. -------------------- Prime Performance - GEN4 3SGTE SWAP SPECIALISTS
www.primemr2.com 862-258-3346 Stanhope, NJ |
Oct 22, 2014 - 9:27 PM
Enthusiast ![]() ![]() Joined Mar 4, '10 From Bronx NY Currently Offline Reputation: 3 (100%) |
Its either the CPU or the Turbo pressure sensor.... Trust me I know ... I had the same problem
-------------------- Always fast and going for the look......
Oct 25, 2014 - 4:37 PM
It was the back of the ECU it had a dent in the back an was grounding it out an pushed the dent out an runs fine but it's having an ideal problem it's about 200 rpms high an sounds like it caming but have the factory cams
| Lo-Fi Version | Time is now: July 30th, 2026 - 3:38 AM |
