> Front mount on ST205 difference?
post Oct 18, 2014 - 12:24 AM
jbod
Joined Oct 15, '10
From Auckland, New Zealand
I am shortly about to do a front mount intercooler on my st205.
What I want to know is, has anyone dont this first hand, on a standard 205, and gained a noticeable difference?
Most people that i know that have done this have gone forged and a big ol turbo at the same time making their input in valuable
Please, dont tell me about my friends done it and he says its great or whatever. I want to truly gauge did it make a difference
My issue with the water to air is on the track the water to air gets hot (intake temp in high 50s) and you feel a loss in power.
If theres no real gain felt I will bore my ct20 out to take a 52mm compressor and give it some chilli sauce - and in the process have to retune the ecu. making the front mount worth while
post Oct 18, 2014 - 5:30 PM
hotgt4
Joined Jul 21, '13
From Gisborne New Zealand
The way i see it is toyota spent thousands of dollars into the 3stge designing it the way they did they made tmic water to air for a reason. if a front mount intcooler was better they would of made it that way from factory . i would say leave it as it is less problems in the future really if you dont wanna have problem with it !
Rip Paul walker
'' DUDE I ALMOST HAD YOU ''
post Oct 19, 2014 - 12:14 AM
jbod
Joined Oct 15, '10
The top mount is inadiquit for the track. Which i do often. It heats up and power is down pretty quick. I know the front mount will keep about 35-40 degrees intake temp as opposed to 55+
I just want to have some feedback does it open up the top end. My feedback so far from a few guys is no, it just drives like the top mount when its cold. Always cooler
post Oct 19, 2014 - 12:30 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
keeping everything the same and converting to a FMIC you will gain a little bit of lag but your intake temps should be lower. Try upgrading the heat exchanger for the WAIC, that will be more efficient
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Oct 19, 2014 - 3:22 AM
jbod
Joined Oct 15, '10
One of my friends has done that has the exchanger from a porsche. Is huge adds another 4l.. However it has the same issue of heat soak, it just lasts longer before the power drops off
post Oct 19, 2014 - 2:20 PM
Rusty
Joined Nov 5, '07
From New Zealand
Do you have heat reflective tape on the bottom of the intercooler?
post Oct 20, 2014 - 1:26 AM
jbod
Joined Oct 15, '10
Indeed, have done that. Tried different mixtures of coolants etc.
I can twll you now it does nothing. Have mapped the temperature with the datalogit .. Not a hair of improvement
post Oct 22, 2014 - 1:13 AM
you need this..
away from the engine..
post Oct 23, 2014 - 3:25 AM
jbod
Joined Oct 15, '10
QUOTE (njccmd2002 @ Oct 22, 2014 - 1:13 AM) *
you need this..
Nope, wont fit, factory airbox is there and that isnt going. Have talked to two people that have done it and have given me the feedback i am after
Cheers guys (: any more appreciated
This post has been edited by jbod: Oct 23, 2014 - 3:25 AM
post Oct 23, 2014 - 4:37 PM
Rusty
Joined Nov 5, '07
From New Zealand
So whats the go FMIC with dry ice or water sprayer?
Lo-Fi Version Time is now: July 29th, 2026 - 5:19 AM
