Oct 18, 2014 - 5:27 PM
Enthusiast ![]() Joined May 8, '14 From Houston Currently Offline Reputation: 1 (100%) |
So will one of the bluetooth adapters work so we can read our check engine codes accurately?
Oct 19, 2014 - 12:33 AM
no, the BEAMS was NOT a USDM engine therefore it does not have ODBII
Oct 19, 2014 - 9:29 AM
I think it'll take some wiring work between the engine harness and chassis harness to make sure all of the wires are in the correct pins but after that it should work. There may not be any wiring work necessary but it's worth checking. After that, all you need is the Bluetooth adapter and an app that supports JOBD. Check out ricochet1490's thread, he has it working on his BEAMS but he used his RHD dash harness so he didn't have to worry about repinning anything.
Oct 19, 2014 - 9:38 AM
My car is a 94 and has no obd2 port anyways.
Anyone know anything about the redtop knock sensor? Mines not hooked up and i need to. The car feels sluggish. I want to know what all is wrong. |
| Lo-Fi Version | Time is now: September 14th, 2026 - 4:33 AM |
