> 88 Alltrac
post Nov 9, 2014 - 5:06 PM
mkernz22
Joined May 10, '10
From MA
Figure I would start this here instead of post more crap in my thread.
As some of you know, I picked up an ST165 Alltrac yesterday.
Yes, I got it for an absolute steal because the guy thought it was seized.
His story: I was pulling into my apartment complex, the engine shut off, and the wheels locked up.
I thought: Okay, doesn't really sound like it seized up...
So I get the car back to my house start charging the battery for a bit and just try cranking it. It turned over slightly because of the dead battery. Kept charging it and about 3 hours later, and after 1 slight catch and die, it starts up just fine. No knocking, no squealing except for the alt belt, sounded amazing, but it kept stalling out. So I gave it gas and held it at 1k rpm's and it would hold there fine on it's own. If I revved it up it would come down, drop below 1k to about 500 and would stall. I figured it had to be vac related cause it was getting everything else.
He told me he had replaced this "coolant" hose on the back side of the engine because it was leaking. The piece he replaced it with was way too long and had 2 kinks in it. Not really that great flowing for coolant. I looked at it more to see where it went, and well I'll be damned, it went to the IAC. No****ingwonder why the car kept stalling out. It wasn't receiving the correct vac at low rpm's. :facepalm: x1,000,000. and this kid is going to New England tech too. So help me god I hope he gets some common sense and learns more.
Now for a list of the mods done to it.
From the PO before this guy:
-Rear poly bushings on all the control arms, don't think he touched the subframe or rear diff, but will check on that
-MR2 rear struts / cut front springs (oh well)
-ST185 front calipers
-CT26 was sent out to a shop and trimmed. Talked to the guy and he said it might be a 60 trim now.
-Exhaust / Water / Oil temp gauges
-Boost gauge (stock still works too)
-HKS Electronic Boost Controller
-Blitz Turbo Timer
-St205 transmission and rear differential. Both are confirmed now.
-gForce ECU chip - semi confirmed, still have to open and check.
-Stupid f*cking hood pins. They're the flushish locking ones. Just need to buy new ones since I don't have the key or get a new hood.
-3" Downpipe to 3" straight exhaust to a Megan Racing muffler.
-JDM block / US head / EGR delete
-ST162 Cams
From the guy I bought it off of:
-Rebuilt bottom end; new pistons, rings, bearings, 1.6 or 1.8mm metal head gasket, ARP headstuds
Photos:
^My cluster**** of a wiring mess I need to clean up and redo. Definitely need some plugs in there...
This post has been edited by mkernz22: Nov 18, 2014 - 11:22 AM
- mkernz22   88 Alltrac   Nov 9, 2014 - 5:06 PM
- - OrangeCelica95   I love those old alltracs. Good buy!   Nov 9, 2014 - 6:29 PM
- - SwissFerdi   Nice. How much is a steal, out of curiosity?   Nov 9, 2014 - 6:31 PM
|- - mkernz22   QUOTE (SwissFerdi @ Nov 9, 2014 - 6...   Nov 9, 2014 - 7:33 PM
- - richee3   That's an awesome buy, Mike! I'm jealo...   Nov 9, 2014 - 7:09 PM
- - njccmd2002   damn. nice... you have the missing parts?   Nov 9, 2014 - 9:59 PM
|- - mkernz22   QUOTE (njccmd2002 @ Nov 9, 2014 - 9...   Nov 9, 2014 - 10:38 PM
- - HaysoosKreesto   QUOTE (mkernz22 @ Nov 9, 2014 - 6:06...   Nov 10, 2014 - 12:45 AM
- - mkernz22   So I cleaned up some wiring, took out the 2 gauges...   Nov 12, 2014 - 6:24 PM
- - mkernz22   AYYYYYYYYYYYYYYYYYYYY! It's gotta gforce c...   Nov 15, 2014 - 9:35 PM
- - jesse09   wat the heck! that is a great deal! That...   Nov 20, 2014 - 7:43 PM
- - mkernz22   Bought some parts for the future brake upgrades. O...   Nov 23, 2014 - 9:00 PM
- - Smaay   welcome to the All-Trac club. sounds like you got ...   Nov 24, 2014 - 9:21 AM
|- - mkernz22   QUOTE (Smaay @ Nov 24, 2014 - 9:21 A...   Dec 1, 2014 - 4:45 PM
- - Box   Why can't I ever find good deals like this? ...   Dec 1, 2014 - 5:32 PM
|- - mkernz22   QUOTE (Box @ Dec 1, 2014 - 5:32 PM) ...   Dec 1, 2014 - 10:29 PM
- - Box   I saw where the dash is kind of similar, and of co...   Dec 1, 2014 - 10:46 PM
- - mkernz22   Brackets came in for the brakes came in In other...   Dec 4, 2014 - 11:34 PM
- - mkernz22   Bought some 550cc 89-91 RX7 Turbo injectors off eB...   Dec 8, 2014 - 6:16 PM
- - mkernz22   Well I've come to the terms that this car isn...   Mar 11, 2015 - 7:13 PM
|- - HaysoosKreesto   QUOTE (mkernz22 @ Mar 11, 2015 - 5:1...   Mar 17, 2015 - 7:52 PM
- - cheela   At least you're in a better place to start th...   Mar 17, 2015 - 8:24 PM
- - Culpable04   that's a really nice ST185, congrats the afte...   Mar 18, 2015 - 9:51 AM
- - mkernz22   Thanks guys, I appreciate it! I'm going to...   Jun 3, 2015 - 11:20 AM
- - mkernz22   Got the other one last week, came with some goodie...   Jul 14, 2015 - 3:55 PM
- - Box   Camo tie-strap holding the liftback down?   Jul 14, 2015 - 4:41 PM
|- - mkernz22   QUOTE (Box @ Jul 14, 2015 - 5:41 PM)...   Jul 14, 2015 - 4:47 PM
- - Box   Whatever helps you sleep at night. That's ok...   Jul 14, 2015 - 5:01 PM
- - mkernz22   Interior went from this: To this: Just couldn...   Jul 18, 2015 - 9:42 PM
- - Box   Wooo!!!! Yeah, blue and red inter...   Jul 18, 2015 - 10:06 PM
- - Bitter   Can add 'stripper' to your resume.   Jul 19, 2015 - 11:20 PM
|- - mkernz22   QUOTE (Bitter @ Jul 20, 2015 - 12:20...   Jul 22, 2015 - 10:01 AM
- - mkernz22   Hey! So it's been a while... This is what...   Oct 16, 2015 - 9:48 PM
- - mkernz22   Going to be taking the car out for a drive tomorro...   Oct 20, 2015 - 8:13 PM
- - mkernz22   Skirts are back on. Almost fixed the coolant iss...   Oct 28, 2015 - 10:29 PM
- - Box   Just in time for Winter shenanigans.   Oct 29, 2015 - 3:41 AM
|- - mkernz22   QUOTE (Box @ Oct 29, 2015 - 4:41 AM)...   Oct 29, 2015 - 9:52 AM
- - mkernz22   Purchased some JDM post face side vents for her. W...   Dec 4, 2015 - 2:27 PM
- - mkernz22   So vents should be here today and I also bought a ...   Jan 19, 2016 - 12:32 PM
- - mkernz22   Finally got my hands on one of these. So hard to f...   Jan 25, 2016 - 1:20 PM
- - mkernz22   Oh and this too. I think it makes the a$...   Jan 25, 2016 - 5:06 PM
- - Malek   Does make it look wider! Looking good man...   Jan 25, 2016 - 7:59 PM
- - Batman722   I'm a fan of the euro plate holder.   Jan 25, 2016 - 9:38 PM
- - njccmd2002   looks great   Jan 25, 2016 - 11:35 PM
- - cheela   it's coming together real nice.   Jan 26, 2016 - 10:20 AM
- - njccmd2002   i envy you, in a good way, love the car   Jan 30, 2016 - 11:06 PM
|- - mkernz22   QUOTE (njccmd2002 @ Jan 30, 2016 - 11...   Jan 31, 2016 - 1:14 AM
|- - GMan   QUOTE (mkernz22 @ Jan 31, 2016 - 1:1...   Feb 1, 2016 - 5:45 PM
|- - mkernz22   QUOTE (GMan @ Feb 1, 2016 - 5:45 PM)...   Feb 1, 2016 - 6:09 PM
- - Bitter   Why not just use the OEM fan switch to flip the re...   Feb 1, 2016 - 8:26 PM
|- - mkernz22   QUOTE (Bitter @ Feb 1, 2016 - 8:26 P...   Feb 1, 2016 - 10:33 PM
- - Bitter   Ok, I was thinking of the later engines and the A ...   Feb 1, 2016 - 10:53 PM
|- - mkernz22   QUOTE (Bitter @ Feb 1, 2016 - 10:53 ...   Feb 1, 2016 - 11:11 PM
- - Bitter   Heck, you could put a bung with a sensor in the in...   Feb 2, 2016 - 12:38 AM
- - mkernz22   Yeahh...that's too much work for now lol Toggl...   Feb 3, 2016 - 12:05 AM
- - mkernz22   Woo, I just got some more parts thanks to Dustin a...   Feb 10, 2016 - 12:19 AM
- - mkernz22   Well I f*cked up the 205 power steering cooler whi...   Feb 26, 2016 - 2:32 PM
- - Box   Obviously Toyota put on a trans cooler for a reaso...   Feb 26, 2016 - 4:15 PM
|- - mkernz22   QUOTE (Box @ Feb 26, 2016 - 4:15 PM)...   Feb 26, 2016 - 10:48 PM
- - Box   Only a letter off.   Feb 27, 2016 - 12:45 AM
- - mkernz22   So I bought $100 in fittings from Summit, whi...   Feb 29, 2016 - 10:44 PM
- - mkernz22   $250 in parts right there... and some more ...   Mar 3, 2016 - 7:47 PM
- - mkernz22   Oil cooler is on the way. Need to mock it up once ...   Mar 7, 2016 - 11:46 PM
- - mkernz22   So good news and bad news. Good news first. Got t...   Mar 10, 2016 - 2:59 PM
- - Box   On the plus side once it's done you won't ...   Mar 10, 2016 - 5:08 PM
- - njccmd2002   250 in just an fittings. Your problem is summit ...   Mar 10, 2016 - 5:41 PM
|- - mkernz22   QUOTE (njccmd2002 @ Mar 10, 2016 - 5...   Mar 10, 2016 - 7:24 PM
- - mkernz22   I'll update with some pictures in a day or two...   Mar 16, 2016 - 11:10 PM
- - mkernz22   Haven't really done much in the past month bec...   Apr 14, 2016 - 8:54 PM
- - njccmd2002   cool beans. Mr2 electric pump. I tought about th...   Apr 15, 2016 - 8:29 AM
|- - mkernz22   QUOTE (njccmd2002 @ Apr 15, 2016 - 9...   Apr 17, 2016 - 1:16 PM
- - Box   Actually I bet you could by using something like a...   Apr 17, 2016 - 1:45 PM
|- - mkernz22   QUOTE (Box @ Apr 17, 2016 - 2:45 PM)...   Apr 18, 2016 - 6:13 PM
- - Bitter   Why? http://www.diyelectriccar.com/forums/showt.....   Apr 18, 2016 - 9:15 PM
- - Box   ^There ya go, life made easier.   Apr 18, 2016 - 10:09 PM
- - mkernz22   QUOTE (Bitter @ Apr 18, 2016 - 10:15...   Apr 18, 2016 - 10:27 PM
- - mkernz22   Well it's been almost a year since I posted.. ...   Apr 5, 2017 - 5:56 PM
- - Bitter   Looks similar to what comes on a Supra. Knowing ho...   Apr 5, 2017 - 7:18 PM
|- - mkernz22   QUOTE (Bitter @ Apr 5, 2017 - 8:18 P...   Apr 6, 2017 - 7:06 AM
- - mkernz22   I've decided to go with a FMIC instead of the ...   Apr 25, 2017 - 8:50 AM
- - mkernz22   This will probably arrive while I'm in Germany...   May 8, 2017 - 12:07 PM
- - Bitter   Hello radiator heat soak   May 8, 2017 - 8:25 PM
|- - mkernz22   QUOTE (Bitter @ May 8, 2017 - 9:25 P...   May 9, 2017 - 11:01 AM
- - mkernz22   Finally some progress on this thing! This will...   Mar 28, 2018 - 7:55 AM
Lo-Fi Version Time is now: August 26th, 2026 - 9:41 PM
