> Lambda Sensor / 02 Exhaust help !
post Dec 1, 2014 - 2:46 PM
MR-AFRO-SS2
Joined Jun 30, '14
From UK ESSEX
ok i have a full system to go on but ran in to a problem once got it on the ramp and see the sensors and on the manifold and decat they are both screw in types with block of screws and the standards are flange type . and not sure how many wires they have.
i was trying to find out what universal ones i needed as see some were that toyota had special ones . i found the original denso ones but unsure what models are the right ones and i know you cant run the upper and lower on each but all is just what i have been reading . im basically looking for options in getting the right sensors or other simple ways of making it work with out codes and running bad . the car is a 94 SS2
PS i will have to extend the wires so will be cutting them any way
post Dec 1, 2014 - 7:01 PM
mi645
Joined May 23, '12
From northridge,CA
i bought an 02 sensor adapter, from fensport uk.
35 bucks, and just used a threaded type o2 sensor, 4 pin. 1 off a lexus. it works fine!
post Dec 2, 2014 - 5:18 AM
MR-AFRO-SS2
Joined Jun 30, '14
From UK ESSEX
it has to be the thread type . but unsure what ones to use as i need the 2 for upper and lower but dont want to get the wrong ones .as heard they are different
post Dec 2, 2014 - 8:02 PM
mi645
Joined May 23, '12
From northridge,CA
my car only has 1 02 sensor plug/port and its an ss2 engine (jdm)
post Dec 3, 2014 - 2:02 AM
Rusty
Joined Nov 5, '07
From New Zealand
you have an O2 sensor & the cat temp sensor
post Dec 3, 2014 - 12:47 PM
MR-AFRO-SS2
Joined Jun 30, '14
From UK ESSEX
ahhh ok so is there a way to disable the temp sensor with out it causing problems or will i have to get another one ?
post Dec 3, 2014 - 2:33 PM
mi645
Joined May 23, '12
From northridge,CA
how many wires per sensor do u have on those 2? 2 pin wires or 4 pin wires?
and im not too sure about the temp sensor for the cat, i know the 02 is more important.
post Dec 3, 2014 - 5:08 PM
MR-AFRO-SS2
Joined Jun 30, '14
From UK ESSEX
unsure i need to check . but when i felt the cat sensor wire it felt like only 1or 2 wires so probably 2 for the 02 . do you know this rusty ?
post Dec 3, 2014 - 9:50 PM
Rusty
Joined Nov 5, '07
From New Zealand
My ST202 96' has a 4 wire -you should be able to see the o2 sensor loom by the extractors. I can't say if earlier years have less, but I'm pretty sure they're 4 wires also
Can't remember the cat temp sensor wire count maybe 1,2? On the dash you have the box with some wavy lines above it thats that sensor. Replace the sensor or clear the code. We found out years ago with a S14a that it went into safe mode
Lo-Fi Version Time is now: June 10th, 2026 - 4:22 AM
